2022-07-30, 21:46
The official LDCad shadow library is up and running at:
https://github.com/RolandMelkert/LDCadShadowLibrary
Its initial commit is based on the 1.7 Alpha 2a csl file.
It just has different headers and uses the CC BY-SA 4.0 license.
I used svn commit data and existing AUTHOR lines to populate the initial !HISTORY section of each file.
The 'official' header format is like so:
The 2nd and later !HISTORY lines should only be appended if needed.
Please use the same format when doing a pull request.
Reason for the general Author:
I wanted to make attribution simpler by letting people attribute the project (permitted by CC BY-SA 4.0 as far I understand it)
Reason for the {name} history lines:
The library is separate from LDraw so using LDraw.org user names might be confusing.
Reason for mentioning the partRefName in a HISTORY line instead of a NAME one:
I now and then move content around while following "move to" changes or to take advantage of new subfiles etc.
Such changes should be noted using something like:
Not sure how to make github track such file renames yet as I usually just copy paste .dat content during shadow editing inside LDCad (it automatically deleted empty shadow files). (EDIT: did some research, git might actually do that automatically if the content of the old and new file are very similar. I guess we'll know when it actually happens )
There are still some other things to sort out / improve upon but I wanted to just get it startedĀ
There will be some tools for editing/creating repo ready shadow files in 1.7 Beta 1.
0 LDCad shadow info for "<sameDescriptionAsOriginalLDrawFile>"
0 Author: LDCad Shadow Library
0 !LICENSE CC BY-SA 4.0, see LICENSE.md
0 !HISTORY YYY-MM-DD {fullAuthorName} Initial info for <partRefName>
0 !HISTORY YYY-MM-DD {fullAuthorName} <shortChangeDescription>
<LDCad meta content>
0 !HISTORY YYY-MM-DD {fullAuthorName} Moved content to <partRefName>
