2022-07-18, 14:20
Here's a guide to numbering for the RCX modules for someone looking to create 1.5 and 2.0:
RCX 1.0 module:
76048: Complete Assembly
32109 (already made): Battery cover
32110: IR "glass" on the front
32116: The green, lower part where the batteries go
32058: The yellow, upper part without the clear plastic screen protector and unprinted
32058p01: 30258 with RCX 1.0 Pattern
32108: The clear plastic screen protector
76113: The yellow, upper part with the clear plastic screen protector
6554 (Already made): The electrical plates, plastic portion
75212: 6554 plus the metal electrical contacts
71748: The circuit board
71645: The gray/green button assembly and the black/red button assembly
Since the top of 884 (the full assembly) is hard coded yellow and I think that part should be color 16, we're going to obsolete 884 and create a new complete assembly with the correct number
RCX 1.5 module:
76454 or 76454c01: Complete Assembly
32374: The yellow, upper part without the clear plastic screen protector and unprinted
32374p01: 32058 with RCX 1.5 Pattern
32374p01c01: The yellow, upper part with the clear plastic screen protector (no number known, unlike 1.0)
?: The circuit board
RCX 2.0 module:
76454a or uXXXX or 76454c02 : Complete Assembly
32374p02: 32058 with RCX 2.0 Pattern
32374p02c01: The yellow, upper part with the clear plastic screen protector (no number known, unlike 1.0)
This post will be update as numbers are known.
RCX 1.0 module:
RCX 1.5 module:
RCX 2.0 module:
