2022-07-10, 11:29
Hey,
this release introduces a complex and powerful feature:
The !LPE CONST meta command.
It allows you to use constants in almost any line type and replace them with a real value when needed.
However, the constants will be removed from a line when the line is modified from another source that is not the constant itself.
When you change a value of a constant afterwards, you need to click manually on the "Update/compile linked subfile data" button.
[attachment=8113]
You can see the calculated value in the warnings section of the text editor.
Syntax:
With that you can do things like:
When you quick fix the warnings for the variable declarations, it will become:
It is possible to use the constants directly in subfiles.
But you can not automatically replace them with a quick fix from the parent file.
subfile.dat
You can also combine it with the CSG or INLINE meta commands.
It does not support !TEXMAP / !: lines yet.
Changelog:
(4 new features)
However, something can go wrong in about 140.000 lines of code.
Installation on Windows:
System Requirements:
Minimum System Requirements:
[attachment=8113]
Syntax:
0 !LPE CONST variable = expression
0 // variable and expression must not contain spaces.
0 !LPE CONST red = 4
0 !LPE CONST green = "0x200ff00"
1 red 3 0 0 1 0 0 0 1 0 0 0 1 box.dat
1 green 0 0 0 1 0 0 0 1 0 0 0 1 box.dat
1 red -3 0 0 1 0 0 0 1 0 0 0 1 box.dat
1 4 3 0 0 1 0 0 0 1 0 0 0 1 box.dat
1 0x200ff00 0 0 0 1 0 0 0 1 0 0 0 1 box.dat
1 4 -3 0 0 1 0 0 0 1 0 0 0 1 box.dat
0 !LPE CONST angle = 20
0 !LPE CONST rx = cos(rad(angle))
0 !LPE CONST ry = sin(rad(angle))
0 !LPE CONST cx = 10*rx
0 !LPE CONST cy = 10*ry
1 7 10 0 0 1 0 0 0 1 0 0 0 1 box.dat
1 8 cx cy 0 rx -ry 0 ry rx 0 0 0 1.5 box.dat
0 !LPE CONST angle = angle+20
1 15 cx cy 0 rx -ry 0 ry rx 0 0 0 2 box.dat
0 !LPE CONST subX = 8
0 !LPE CONST subY = 2
0 !LPE CONST subZ = 3
1 16 0 0 0 1 0 0 0 1 0 0 0 1 subfile.dat
subfile.dat
2 24 0 0 0 subX subY subZ
1 16 subX subY subZ 1 0 0 0 1 0 0 0 1 8-8sphe.dat
0 !LPE CSG_QUALITY 16
0 !LPE CONST cubeH = 1
0 !LPE CONST cubeH2 = cubeH*2
0 !LPE CONST sphereH = cubeH*1.35
0 // Won't override CSG constants
0 !LPE CONST csgA = 42
0 !LPE CSG_CUBOID csgA 4 0 0 0 cubeH 0 0 0 cubeH 0 0 0 cubeH
0 !LPE CSG_ELLIPSOID csgB 1 0 0 0 sphereH 0 0 0 sphereH 0 0 0 sphereH
0 !LPE CSG_CYLINDER csgC 2 0 -cubeH 0 .7 0 0 0 cubeH2 0 0 0 .7
0 !LPE CSG_CYLINDER csgD 2 -cubeH 0 0 0 cubeH2 0 .7 0 0 0 0 .7
0 !LPE CSG_CYLINDER csgE 2 0 0 -cubeH .7 0 0 0 0 .7 0 cubeH2 0
0 !LPE CSG_UNION csgC csgD csgD
0 !LPE CSG_UNION csgD csgE csgD
0 !LPE CSG_INTERSECTION csgA csgB csgF
0 !LPE CSG_DIFFERENCE csgF csgD csgF
0 !LPE CSG_COMPILE csgF
Changelog:
(4 new features)
- ...use the "!LPE CONST" meta command to define re-usable constants in parts and subparts.
- ...use calculated expressions for constants, too.
- ...quick-fix/replace constants with the text editor.
- ...combine "!LPE CONST" with "!LPE CSG" meta commands (but not with !TEXMAP commands, yet).
- Download and extract LDPartEditor_win32_x64.zip
- Run LDPartEditor-1.8.60.msi
- Start LDPartEditor from the start menu
- Download and extract LDPartEditor_linux_x64.zip
- Install ldparteditor_1.8.60-1_amd64.deb
- Start LDPartEditor from the menu or via launcher
- Download and extract LDPartEditor_mac_x64.zip
- Mount LDPartEditor-1.8.60.dmg
- Drag LDPartEditor.app to the Applications folder
- Copy ldparteditor.sh to your home folder
4a. Open a Terminal.app and run ./ldparteditor.sh
4b. Or open a Terminal.app and run /Applications/LDPartEditor.app/Contents/MacOS/LDPartEditor
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
