This is another one of those where it doesn't look like there's enough information to solve it, but there's clearly only one solution, so there must be!
Consider the case of a pole leaning inside a barrel, such that it rests against both sides and the bottom, forming the three points A, C, and E. These three points and the inside corners of the barrel form two similar right triangles, ABC and CDE.
attachment=8097]
From the known part dimensions, we get the hypotenuse (8) of the smaller triangle and one leg (36) of the larger triangle. We also know that an additional leg from each triangle, BC and CD, add up to 26.
We want to find the missing lengths AC, BC, CD and DE, and by extension, the congruent acute angles at A and C. That will give us the rotation points and angle for the bar. Can we do it?
I let GeoGebra do the job and it tells me that the 0 point for 8 - ((26-36 tan (A))/cos(A)) is 27,7222764 degrees
Making BC = 18,91828 LDU
That's interesting question. Although the initial conditions are easy to formalize, they let to an eq. of degree 4 - or I'm missing something
let set y=|DE| ; l=|BC| ; r=|CD|; S=26; V=36; T=8 - then:
L + R = S (evident)
R^2 + y^2 = T^2 (Pythagoras theorem)
y/R = L / V (similar triangles)
Another approach is to use analytic geometry: for each point C compute the eq. of bar bottom-right corner point- then, set the x coordinate of this point equal 26. Maybe I try this later but you might be faster
EDIT: This leads to eq. of degree 4 as well. Hmm, strange. Not only because of a need to solve such eq. but from physical POV as well: how we can tell why only one of those 4 solutions is real and other three not? Looks, I felt into a trap, I can see why this was announced as a puzzle now
(2022-07-08, 9:18)Gerald Lasser Wrote: [ -> ]I let GeoGebra do the job and it tells me that the 0 point for 8 - ((26-36 tan (A))/cos(A)) is 27,7222764 degrees
What did you enter into GeoGebra to find this? I
sketched it there myself, but I don't know how to enter all of the constraints I need. (Dimensions are different in my sketch because I was dealing with different parts, but the problem is the same.)
(2022-07-08, 14:40)N. W. Perry Wrote: [ -> ]What did you enter into GeoGebra to find this? I sketched it there myself, but I don't know how to enter all of the constraints I need. (Dimensions are different in my sketch because I was dealing with different parts, but the problem is the same.)
Basically I made a function that shall solve to 0 at the given angle
so given that:
angle ABC = angle CDE
BC+CD = 26
I took:
tan(ABC)= BC/36
BC=36*tan(ABC)
and then
CD= 8*cos(ABC)
26 - 36*tan(ABC) = 8* cos(ABC)
so I made a graph for
f(ABC) = 26 - 36*tan(ABC) - 8* cos(ABC)
then the term get 0 we have a solution
attachment=8100]
(2022-07-08, 17:05)Gerald Lasser Wrote: [ -> ]Basically I made a function that shall solve to 0 at the given angle
so given that:
BC+CD = 26
Right, except it's BAC and DCE in the picture, but no matter…
Quote:I took:
tan(ABC)= BC/36
BC=36*tan(ABC)
Got it, tan=O/A…
Quote:and then
CD= 8*cos(ABC)
And cos=A/H…
Of course, since the two sides are equal, subtract one side from the other to get zero…
Quote:then the term get 0 we have a solution
So the solution is 0.483845377…? How does we get 27.7222764 degrees from that?
Sorry, I'm still slow with the algebra side of it!
(2022-07-09, 2:45)N. W. Perry Wrote: [ -> ]So the solution is 0.483845377…? How does we get 27.7222764 degrees from that?
0.48 is in Radians, i.e. a full circle (360 °) is 2*pi
So 0.48/(2*pi) *360 you get degrees
(2022-07-09, 9:04)Gerald Lasser Wrote: [ -> ]0.48 is in Radians, i.e. a full circle (360 °) is 2*pi
D'oh! Of course, radians. Those get me every time.
And of course I tried this angle, and it does appear to be correct!
(2022-07-09, 20:29)N. W. Perry Wrote: [ -> ]D'oh! Of course, radians. Those get me every time.
Sure, it's good to solve the practical problem. But I am really surprised I couldn't find any analytic solution, a clear statement L=f(s,v,b) as I wrote lower. Strange. Such easily-formulated problem leading to so complicated solution?
Hello: I am not a mathematician but, on my knowledge, the equation in the graph is wrong: you change the sign of 36tan(x); it is -36tan(x) when in reality is +36tan(x)
(2022-07-09, 22:27)Javier Orquera Wrote: [ -> ]Hello: I am not a mathematician but, on my knowledge, the equation in the graph is wrong: you change the sign of 36tan(x); it is -36tan(x) when in reality is +36tan(x)
I haven't figured out the graph equation, either…as far as I can see, it's enough to put f(x) = 26 - 36tan(x) - 8cos(x). But the software will rearrange it as it sees fit, I suppose…
