2022-07-05, 18:48
here are just 3 more bugfixes
I had to fix one new issue from the 1.8.58 release.
Changelog:
(3 bug fixes)
With this release the following critical issues were fixed:
However, something can go wrong in about 140.000 lines of code.
Installation on Windows:
System Requirements:
Minimum System Requirements:
Changelog:
(3 bug fixes)
- The middle mouse button rotation was locked (in combination with the Alt key).
- Different lines were marked as hidden in the text editor.
- When the source lines came from an offset subpart, Ytruder's "symmetry across plane" didn't create the correct result.
- Download and extract LDPartEditor_win32_x64.zip
- Run LDPartEditor-1.8.59.msi
- Start LDPartEditor from the start menu
- Download and extract LDPartEditor_linux_x64.zip
- Install ldparteditor_1.8.59-1_amd64.deb
- Start LDPartEditor from the menu or via launcher
- Download and extract LDPartEditor_mac_x64.zip
- Mount LDPartEditor-1.8.59.dmg
- Drag LDPartEditor.app to the Applications folder
- Copy ldparteditor.sh to your home folder
4a. Open a Terminal.app and run ./ldparteditor.sh
4b. Or open a Terminal.app and run /Applications/LDPartEditor.app/Contents/MacOS/LDPartEditor
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
