Can someone help me with Sticker 192685i for 1581-1 (Silja Lines Ferry)
attachment=8077]
Unfortunately I dont have Set or Sticker (both quite rare), but the Logo exists as SVG:
https://fi.wikipedia.org/wiki/Tiedosto:S...n_logo.svg
For the general size, there is a Bricklink-Seller who sells the nearly empty sheet, shall we ask there how big this sticker is?
https://www.bricklink.com/v2/catalog/cat...only%22:0}
For the digital version, maxbe we should check if the other Ferries (1580-2, 1554-1) with a very similar sticker actually have the same sticker...
The newest ferry 1998-1 has a similar sticker, but blue and separated.
looking at the picture from
https://thumbs.worthpoint.com/zoom/image...0c5ecb.jpg
The left end is not very clearly seen, but better in this image (second window)
the dimensions can be gatherd.
In the first picture 4 studs are 170 pixels
One brick height is 50 pixels.
Sticker is 370 pixels long (174 LDU)
Sticker height at the text is 56 pixels (~ 27 LDU) this extends for 256 pixels (122 LDU)
Raising from 56 Pixels to 109 pixels over a distance of 19 pixes (~9 LDU)
Sticker height at the Walrus is 109 pixels (~ 52,5 LDU)
Sticker hright of 109 extends 37 pixels (17,6 LDU) to the right
then dropping on the right corner to a height of 62 (~30 LDU)
That should be pretty much the dimensions, I have not found a better picture
Edit:
There is a converter SvgToDat, but it does not like the Logo
Set 1554 and 1581, Silja Line Ferries
attachment=9007]
Missing: Stickers with name of the boats
OMR: not
(2023-01-07, 9:22)Magnus Forsberg Wrote: [ -> ]Set 1554 and 1581, Silja Line Ferries
OMR: not
Magnus, thanks for the the letters.
Here is a my suggestion on a colour for all the printed parts and stickers used on this ferries.
None of our standard blue are correct.
I want to use a custom blue, the bottom one on this image. #37A1E8
attachment=9807]
If I use ColourSum on this hexcode I get Medium Azure, but that one is too yellow.
Edit: Added more standard colours on the image.
(2023-07-26, 20:44)Magnus Forsberg Wrote: [ -> ]Here is a my suggestion on a colour for all the printed parts and stickers used on this ferries.
How close is Maersk blue?
(2023-07-26, 20:44)Magnus Forsberg Wrote: [ -> ]I want to use a custom blue, the bottom one on this image. #37A1E8
Direct colors are
explicitly allowed in patterns and stickers, so even if there aren't any matches in LDConfig.ldr, you are free to use an exact RGB color. The LDraw color code for your preferred color would be 0x237A1E8.
(2023-07-27, 0:03)Travis Cobbs Wrote: [ -> ]Direct colors are explicitly allowed in patterns and stickers, so even if there aren't any matches in LDConfig.ldr, you are free to use an exact RGB color. The LDraw color code for your preferred color would be 0x237A1E8.
Note also that we don't
want to add colors that only show up in patterns to LDConfig.ldr.
All the stickers for these ferries are now on the PT.
I guess I should ask like this, and want to know if,
Do you think it is OK to change the colours on all the bricks that have been official more than 10 years?
You have my OK if you want to correct the bricks and stickers...
