(2022-06-19, 17:38)Stephan den Ridder Wrote: [ -> ]I would like to request the following parts if possible:
Hello Stephan:
- 70694 & 35635: acording to digital-bricks.de thise parts are in the lego microgame
- 80677: solemne skilled (even in blender!) can do that; problem is: some sources entitle the part as a Tile 2 x 2 and others as Tile 3 x 3.
Hope I Hello YouTube.
All 3 are available in our usual sources so if those in the know want to pick these up it should be easy.
(2022-06-27, 18:53)Fredrik Hareide Wrote: [ -> ]I can try to do 70694
Awesome!
Updated with a request for 424.
Bump
Since the meshes are available elsewhere and vacation period is almost over: a small bump
I also requested the new stud shooters now
I noticed the stud shooters were added! Awesome.
Updated witha request for 67929.
Updated with a request for 1746.
(2022-12-10, 16:25)Stephan den Ridder Wrote: [ -> ]Updated with a request for 1746.
Here is the raw, uncleaned mesh. Origin/orientation should be OK. Some tubes (stud4) missing below.
(2022-12-11, 7:51)Philippe Hurbain Wrote: [ -> ]Here is the raw, uncleaned mesh. Origin/orientation should be OK. Some tubes (stud4) missing below.
Cleaning started!
80566
80564
80562
I downloaded 2 files from another Thread, but it's missing the torrus2.dat file
Added a deconstruction link for the light-up figures.
Awesome! Luckily the list is getting shorter and shorter!
Updated with 3262 which is the regular 2x2 dome part but with a vented stud (like on the new transparent Minifigure head).
(2023-01-09, 8:56)Stephan den Ridder Wrote: [ -> ]Updated with 3262 which is the regular 2x2 dome part but with a vented stud (like on the new transparent Minifigure head).
We need more information to make this one.
- Is there and axle hole, inside the bottom stud? What sort of axlehole?
- Is there supports on the inside? In what position?
- How is the bottom designed, between the stud slots? Flat or curved?
Have you any images of the bottom?
(2023-01-09, 16:25)Magnus Forsberg Wrote: [ -> ]We need more information to make this one.
The underside should be the same as
this one, but I have no pictures.
Hello: I extrated 2 of the parts from Lego app. The part 3262 have no stud. Part 40145 is from Stud.io. All of the part are unprocessed. Hope I help.
(2023-01-10, 18:20)Javier Orquera Wrote: [ -> ]Hello: I extrated 2 of the parts from Lego app. The part 3262 have no stud. Part 40145 is from Stud.io. All of the part are unprocessed. Hope I help.
I will clean up 3262.
3262 ist not correclty represented in the app IMHO, it is listed to have a hole, the data from the app shows otherwise. There are currently many aliases of 3262 to build with, so the part is not really urgent. I guess we need a picture of the part.
