Full Version: Optimus Prime parts
Pages: 1 2
   Would like assistance with parts from the new Optimus Prime set (10302):
1762 / 67421 Slope 33 2x3 double / inverted (It is in mecabricks though.   I didn't now how to export it.)
53029 Hinge Brick 2x2 Locking with 2 Fingers Vertical and Cross Style Axle Hole, 7 Teeth There is a dat file in github but doesn't load properly in Part Designer
73304 Power Burst Figure Pedestal 5x5 x 2/3.  Not in Github
3660 / 76959 Slope, Inverted 45 2x2 with Hollow Round Bottom Tube.  Also on Mecabricks
Thanks for the great work you do
George
I am working on 1762, should be done tomorrow
Instead of 53029, you can use 40902
The 73304 is on the Parts Tracker as 35032e
You can find 3660 also on the Parts Tracker
BR
(2022-06-14, 9:56)Gerald Lasser Wrote: [ -> ]I am working on 1762, should be done tomorrow
BR
Thanks Gerald,
         I had some issues importing 40902 and 3660 into PartDesigner.  I ended up just importing each brick from LDCad.  Is there something I need to do to import those two parts properly into PartDesigner?
George
(2022-06-14, 9:56)Gerald Lasser Wrote: [ -> ]The 73304 is on the Parts Tracker as 35032e
That's a different part. The outline might be similar (or even the same, not sure), but the center is totally different.
(2022-06-16, 3:37)Travis Cobbs Wrote: [ -> ]That's a different part. The outline might be similar (or even the same, not sure), but the center is totally different.
Thanks for clarifying, Travis.
Here is a mesh of 73304, origin corrected according to our specs.
No other touch ups done
(2022-06-16, 12:12)Gerald Lasser Wrote: [ -> ]Here is a mesh of 73304, origin corrected according to our specs.
Thanks Gerald!  BTW, any luck on 1762?
George
(2022-06-21, 20:12)George Hsia Wrote: [ -> ]Thanks Gerald!  BTW, any luck on 1762?
George
Here you are, sorry for the delay
https://www.ldraw.org/cgi-bin/ptdetail.c...s/1762.dat
[Image: 1762.png]
(2022-06-14, 5:19)George Hsia Wrote: [ -> ]53029 Hinge Brick 2x2 Locking with 2 Fingers Vertical and Cross Style Axle Hole, 7 Teeth
53029 is made, and is on the Part Tracker
[Image: 53029.png]
https://www.ldraw.org/cgi-bin/ptdetail.c.../53029.dat
Pages: 1 2
