Would like assistance with parts from the new Optimus Prime set (10302):
1762 / 67421 Slope 33 2x3 double / inverted (It is in mecabricks though. I didn't now how to export it.)
53029 Hinge Brick 2x2 Locking with 2 Fingers Vertical and Cross Style Axle Hole, 7 Teeth There is a dat file in github but doesn't load properly in Part Designer
73304 Power Burst Figure Pedestal 5x5 x 2/3. Not in Github
3660 / 76959 Slope, Inverted 45 2x2 with Hollow Round Bottom Tube. Also on Mecabricks
Thanks for the great work you do
George
I am working on 1762, should be done tomorrow
Instead of 53029, you can use
40902
The 73304 is on the Parts Tracker as
35032e
You can find
3660 also on the Parts Tracker
BR
(2022-06-14, 9:56)Gerald Lasser Wrote: [ -> ]I am working on 1762, should be done tomorrow
Instead of 53029, you can use 40902
The 73304 is on the Parts Tracker as 35032e
You can find 3660 also on the Parts Tracker
BR
Thanks Gerald,
I had some issues importing 40902 and 3660 into PartDesigner. I ended up just importing each brick from LDCad. Is there something I need to do to import those two parts properly into PartDesigner?
George
(2022-06-14, 9:56)Gerald Lasser Wrote: [ -> ]The 73304 is on the Parts Tracker as 35032e
That's a different part. The outline might be similar (or even the same, not sure), but the center is totally different.
(2022-06-16, 3:37)Travis Cobbs Wrote: [ -> ]That's a different part. The outline might be similar (or even the same, not sure), but the center is totally different.
Thanks for clarifying, Travis.
Here is a mesh of 73304, origin corrected according to our specs.
No other touch ups done
(2022-06-16, 12:12)Gerald Lasser Wrote: [ -> ]Here is a mesh of 73304, origin corrected according to our specs.
Thanks Gerald! BTW, any luck on 1762?
George
(2022-06-23, 18:52)George Hsia Wrote: [ -> ]Thanks Gerald. I imported into Part designer -> Lego Studio but seems to be having issues snapping to 2x2 plates. Have you seen any issues?
Which connections did you add?
I am not using PD daily, but when I add these three bottom-connections according to these scheme in the picture it will snap to a 2x2 plate and also to a single stud between the ribs. Strange that one position is 0,41 to fit exactly.
attachment=8054]
edit: turns out nice, edit once more, correct colour now
attachment=8056]
(2022-06-23, 20:17)Gerald Lasser Wrote: [ -> ]Which connections did you add?
I'm just added the connections and works great! Thanks.
George
(2022-06-23, 21:50)George Hsia Wrote: [ -> ]Thanks Magnus,
Sorry I'm a noob at PartDesigner. I get the following error (see attachment).
George
Yeah I'm like a month late or smth, but it is a problem you can deal with by copying the subpart you need to both [Studio install directory]\ldraw\parts\s and C:\Users\murta\AppData\Local\Stud.io\CustomParts\parts\s
Prob there is a way more convenient way to do that but I'm not aware of that
(2022-07-09, 21:37)Max Murtazin Wrote: [ -> ]Yeah I'm like a month late or smth, but it is a problem you can deal with by copying the subpart you need to both [Studio install directory]\ldraw\parts\s and C:\Users\murta\AppData\Local\Stud.io\CustomParts\parts\s
Thanks Max, I appreciate the follow-up. I figured it out shortly after posting my message. I only added the subpart to the User AppData directory, but so far so good. Thanks!
(2022-07-11, 3:14)George Hsia Wrote: [ -> ]Thanks Max, I appreciate the follow-up. I figured it out shortly after posting my message. I only added the subpart to the User AppData directory, but so far so good. Thanks!
Yes that's the way to go. Afaik the only type of files that need to be added to studio internal library is new primitives. Studio itself finds them properly in CustomParts \p folder, but parts designer needs them in internal library.
