I'm going to add some clarification to the sticker numbering section of the Part Number Spec to state that if the stickers are numbered on the sheet then the corresponding letter (e.g. 1 = a, 2= b) should be used as the letter suffix. I don't think this constitutes a material and, therefore, votable change but we can vote if either of you would like.
(2022-05-26, 14:23)Orion Pobursky Wrote: [ -> ]I'm going to add some clarification to the sticker numbering section of the Part Number Spec to state that if the stickers are numbered on the sheet then the corresponding letter (e.g. 1 = a, 2= b) should be used as the letter suffix. I don't think this constitutes a material and, therefore, votable change but we can vote if either of you would like.
I'm ok with leaving this up to you.
