Full Version: 1.8.55 Beta Released (bugfixes / invisible subparts / usability)
Hey,
this version fixes many bugs and supports "invisible subparts".
It is not required to uninstall the previous LDPartEditor version, before installing version 1.8.55.
LDPE uses now a very modern technology stack and does not need a Java installation anymore.
[Image: attachment.php?aid=12753]
Changelog:
(3 new features and 9 bug fixes)
  • ...to see a warning for subpart references with no content. You can also transform empty subparts and "see" them as a single vertex in the 3D editor.
  • ...use "Show Selection in Text Editor" to show the first line that uses that vertex, when you selected a vertex (or the next lines when you repeat the function).
  • ...benefit from a better contrast of hidden lines in the text editor.
  1. Empty primitives couldn't be selected/rotated (e.g. 1-16chrd's)
  2. The zoom value for newly created files was not the default value (3D Editor)
  3. When the user did not wanted to save the file in the text editor it was still displayed in the 3D editor.
  4. "Show selection in 3D View" did not select the vertices from subfiles.
  5. When you used separate text and 3D windows and created a new file, a new text window was opened, instead of using a new tab in the already opened text window.
  6. If you used "save as", a new file was created, but no text window or tab was created, although the sync tabs button was active.
  7. "Sync. 3D Editor Tabs with Text Editor" setting was sometimes deactivated.
  8. (back-ported to 1.8.54) LDPartEditor 1.8.54 won't start on Linux (because of a classpath error)
  9. Minor IO error regarding the "(no file selected)" tab.
Installation on Windows:
  1. Download and extract LDPartEditor_win32_x64.zip
  2. Run LDPartEditor-1.8.55.msi
  3. Start LDPartEditor from the start menu
Installation on Linux:
  1. Download and extract LDPartEditor_linux_x64.zip
  2. Install ldparteditor_1.8.55-1_amd64.deb
  3. Start LDPartEditor from the menu or via launcher
Installation on Mac OS X:
  1. Download and extract LDPartEditor_mac_x64.zip
  2. Mount LDPartEditor-1.8.55.dmg
  3. Drag LDPartEditor.app to the Applications folder
  4. Copy ldparteditor.sh to your home folder
        4a. Open a Terminal.app and run ./ldparteditor.sh
        4b. Or open a Terminal.app and run /Applications/LDPartEditor.app/Contents/MacOS/LDPartEditor
Please note that this software is in the beta stage. Although, this version was tested, there are already known issues  for this release. There is a potential risk of data loss.
System Requirements:
Minimum System Requirements:
  • Operating System (64-bit): Windows [7 or newer], Linux [e.g. Ubuntu Linux >=14.4], Mac OS X [>=10.6]
  • RAM: 4GB
  • Video-Memory: 1 GB
  • Free Disk Space: 100 MB
Recommended Requirements:
  • Operating System (64bit): Windows 7,8,10, Linux [e.g. Ubuntu Linux >=14.4], Mac OS X [>=10.6]
  • OpenGL 3.3 compatible Graphics Card
  • RAM: >4 GB
  • Video-Memory: >1 GB
  • Free Disk Space: 512 MB
  • For a faster start, LDPartEditor and the LDraw™ library should be installed on an SSD.
Thanks Nils,
(2022-04-26, 20:02)Nils Schmidt Wrote: [ -> ]
Related problems I noticed:
- "empty" subfiles are reported as scaled in X, Y and Z directions. If I inadvertently fix errors in X or Z directions the underlying geometry gets scaled/distorted.
- Hidden "empty" subfiles are not marked empty in text editor, even though the materialization vertex in 3D editor is properly hidden.
Quote:The following critical issues were fixed:
Thanks for that too!
...and completely unrelated: is it possible to assign a keyboard shortcut to line to condline and condline to line conversion functions?
(2022-04-27, 8:39)Philippe Hurbain Wrote: [ -> ]- "empty" subfiles are reported as scaled in X, Y and Z directions. If I inadvertently fix errors in X or Z directions the underlying geometry gets scaled/distorted.
I created issue #897 for the next release.
Quote:- Hidden "empty" subfiles are not marked empty in text editor, even though the materialization vertex in 3D editor is properly hidden.
That is actually a feature. If you select a single vertex, it will activate "Single Vertex Modification" and show everything in text editor while it is active (regardless if it is hidden).
The idea behind this is that the user might want to see where the vertex is used, even if that usage is hidden in the 3D view.
Quote:...and completely unrelated: is it possible to assign a keyboard shortcut to line to condline and condline to line conversion functions?
What keyboard shortcut do you want to have? :) (it is not possible yet)
(2022-04-27, 20:41)Nils Schmidt Wrote: [ -> ]That is actually a feature. If you select a single vertex, it will activate "Single Vertex Modification" and show everything in text editor while it is active (regardless if it is hidden).
I reckon that. But I was in subpart selection mode, not in vertex selection mode!
Quote:What keyboard shortcut do you want to have? Smile (it is not possible yet)
let's say shift+C for C2L and shift+L for L2C. I guess it will be possible to personalize afterwards Wink
(2022-04-28, 6:56)Philippe Hurbain Wrote: [ -> ]I reckon that. But I was in subpart selection mode, not in vertex selection mode!
I think it should be reversed. Makes a bit more sense when key stands for result, not for target
(2022-04-28, 7:14)Max Murtazin Wrote: [ -> ]I think it should be reversed. Makes a bit more sense when key stands for result, not for target
...I am "directionally challenged"  Big Grin
