2022-03-24, 20:31
An updated version of the LDraw All-In-One-Installer, in short AIOI, containing the LDraw Parts Library update 2022-02 with 366 new files (including 196 new parts and 12 new primitives) has been released.
The AIOI supports Windows XP (Home and Pro), Windows Vista or higher (all versions). There are two installer files available: Use the 64 Bit AIOI to install all the main 64 Bit programs, while the older 32 Bit programs are offered in a separated .exe file. Please note that only the 64 Bit version contains the LDraw Parts Library. If you want to use the 32 Bit programs it is mandatory that the library has been installed previously. The Installer will NOT run on Windows 95, 98, ME, NT Ver 4, 2000, or XP below SP2.
It contains the following changes:
* Update to Parts Library 2022-02
* Update to MLCad.ini 2022-02
* Update to Offline Parts Catalog 2022-02
* Update to LDView 4.4.1
You can download the AIOI from:
LDraw.org >> Help >> Get Started >> Windows >> LDraw All-In-One-Installer
Many thanks to all the programmers who contributed to this release.
Willy Tschager
(LDraw.org Content Manager)
Willy Tschager
