I was not able to find
78c13 on the parts tracker and would like to use it in my Rock Raiders Power Station moc. I would like to request 78c13.
Hi Tom,
This should be
71945
Look into LDCads parts bins in Hose and filter for Ribbed
Gerald
Thank you for pointing me in the right direction =)
(2022-03-21, 14:44)Orion Pobursky Wrote: [ -> ]In the future, if you can't find a part, try looking on Rebrickable. They have an excellent LDraw number cross reference. For example here's 78c13:
https://rebrickable.com/parts/78c13/hose...7mm-d-13l/
If you look, the LDraw number is listed as 71945.
Good to know. I use Rebrickable a lot. Next time I will check Rebrickable first.
I do not know why, but after downloading
71945.dat from the parts tracker and importing the
71945.dat file into PartDesigner it says it is missing the subfiles. I had this issue with part
32064c as well. I think this is a bug, because I do not remember this happening with other parts in the past.
![[Image: X5OOXsI.png]](https://i.imgur.com/X5OOXsI.png)
I tried it, but it seems that it also wants to have s/71944s01.dat. So I downloaded that file as well, but it seems that it specificly wants the file name to match it. Windows does not allow a / in the name, so I got stuck again.
I had to change the name in each part file mentioning s/71944s01.dat to 71944s01.dat to solve this problem.
Thanks for the help! Hopefully this tube gets added soon. I will at least try to get it into the cheenzo parts github repository for everyone to use. I would like to be able to use it in a Rock Raider MOC.
(2022-04-06, 16:15)Thom Kok Wrote: [ -> ]I tried it, but it seems that it also wants to have s/71944s01.dat. So I downloaded that file as well, but it seems that it specificly wants the file name to match it. Windows does not allow a / in the name, so I got stuck again.
You could also have created a folder named s in the same folder as 71945.dat and put the 71944s01.dat inside without modifying the content of other files
(2022-04-06, 16:19)Vincent Messenet Wrote: [ -> ]You could also have created a folder named s in the same folder as 71945.dat and put the 71944s01.dat inside without modifying the content of other files
Oh I did not think about that. That is a good idea.
