2022-03-07, 17:20
Hello everyone,
The attached script (just change .txt to .lua) lets you write words in a Duplo or Lego font.
Just change the part and factor variables in addLetter to get the different versions. For brevity, the letters are defined using positions by studs and brick height and are multiplied by the factor to get coordinates. As such, they will work for any brick that is 2 studs wide with height 1.
Question: Is it possible to add a group in an an LDCad script? I'd like to add the parts in each letter to a group, and then add a group for the entire word. The best example I have seen is in the Add Wall example script, but that just adds the new parts to the selection.
Thank you,
Mike
[attachment=7639]
function addLetter(color, studOffset, letter)
-- Duplo
-- local part = '3437.dat'
-- local factor = ldc.vector(40, -48, 40)
-- Lego
local part = '3003.dat'
local factor = ldc.vector(20, -24, 20)
Thank you,
Mike
[attachment=7639]
