2022-02-18, 18:33
Some Duplo parts (and a handful of others) don't have a proper CATEGORY. Unless there's major objection, I plan on recycling and fastracking these parts to add one. I can post a list if desired.
(2022-02-18, 18:33)Orion Pobursky Wrote: [ -> ]Some Duplo parts (and a handful of others) don't have a proper CATEGORY. Unless there's major objection, I plan on recycling and fastracking these parts to add one. I can post a list if desired.We discussed the possibility to create a new Duplo category. Maybe that would be the opportunity to do that?
(2022-02-18, 20:38)Philippe Hurbain Wrote: [ -> ]We discussed the possibility to create a new Duplo category. Maybe that would be the opportunity to do that?
(2022-02-18, 21:29)Travis Cobbs Wrote: [ -> ]The current official library definitely has parts that are in the Duplo category, although I don't know if that is due to their name or a !CATEGORY line. (My script that creates the parts library overview PDF for Willy separates parts by category, and Duplo is one of the categories.)
(2022-02-18, 21:58)Orion Pobursky Wrote: [ -> ]Duplo isn't on the list so it's being defined by first word. The other one with a few entries is String.
(2022-02-18, 22:33)Travis Cobbs Wrote: [ -> ]I'm not sure what list you are talking about. Does the PT have a list of valid categories, and it rejects files !CATEGORY lines that aren't in that list? If so, could it be updated to reject based on the first word if the file doesn't have a !CATEGORY line?
(2022-02-18, 22:44)Orion Pobursky Wrote: [ -> ]The list is in the !CATEGORY spec.
I did find the list in the PT code but IDK if the PT rejects invalid categories on submit or if there some other prior to release check.
Orion Pobursky Wrote:Duplo isn't on the list so it's being defined by first word.
(2022-02-19, 6:29)Travis Cobb Wrote: [ -> ]I still don't understand the logic that allowed you to say this:
(2022-02-19, 7:17)Magnus Forsberg Wrote: [ -> ]I know, after testing, that DatHeader is checking that list and force an addition of a valid category if the first word isn't in the list.
Duplo is not in the list and if you check the parts, "Duplo Brick ..." use !Category Brick, "Duplo Plate ..." use !Category Plate, "Duplo Axle ..." use !Category Technic, and so on.
But I can also find some older part that don't have a Category line.
Almost all "Duplo Tile ... " are missing a category.
