Full Version: Step for moving parts
Does anyone know if LDraw allows to create step for moving some parts (instead of adding)?
For a complex model, it is very common to add a part (like a pin) to a component, then push it in when connecting to another component. But I haven't found a way to make such instruction in LDraw.
Thanks!
(2021-12-03, 23:42)mihao Wrote: [ -> ]Does anyone know if LDraw allows to create step for moving some parts (instead of adding)?
Thanks!
There are a couple of solutions for this, none of which is 100% ideal. The most widely used is buffer exchange, a set of metas from MLCad that's also understood by LPub and LDCad. LPub also has a new feature called Build Mod[ification], which is supposed to update this process but I think isn't fully implemented yet.
Documentation for these features isn't great—the best way to learn about them may be to search this forum.
(2021-12-04, 2:36)N. W. Perry Wrote: [ -> ]There are a couple of solutions for this, none of which is 100% ideal. The most widely used is buffer exchange, a set of metas from MLCad that's also understood by LPub and LDCad. LPub also has a new feature called Build Mod[ification], which is supposed to update this process but I think isn't fully implemented yet.
Thank you! I'll look up for it. Sounds very promising!
Big Grin Big Grin Big Grin
Actually I just tried build modification, and it seems to be working well. One question, is there a good way to indicate the moved parts in the build mod step? Thanks!
