Hi
new here - but have used LDCad for almost 2 years - perfect program !! - got a problem, suddenly PART SNAPPING will not work even if it is turned on - anyone how can help?
Thanks in advance !
DKD (Dan)
(2021-11-04, 13:41)dkd Wrote: [ -> ]Hi
Thanks in advance !
DKD (Dan)
Have you downloaded a new version of LDCad recently? Or changed anything in your configuration, or file system?
First thing to check is Prefs->LDraw->Search (library) paths… What shadow library does it point to?
attachment=7096]
(2021-11-05, 0:15)N. W. Perry Wrote: [ -> ]Have you downloaded a new version of LDCad recently? Or changed anything in your configuration, or file system?
hi !
Thanks for your quick reply - have 1.6 and 1.7 AND! no shadow libery - problem solved! everything is as it should be now, after changing it
again many thanks
DKD
