I'm trying to build a library of game-ready parts for use in video games, and would like a library of low-poly bricks to fall back on for bricks I have not yet converted by hand. I've dug around and tried a few methods so far, but all have failed to work.
LdrDat2Obj: Processes 1,466 dats out of the 14,038 in ldraw's parts directory, and then exits silently with no error or log. the last brick it appears to process is 22385p050.dat It processes the parts in an order I can't decipher, so skipping this last brick and moving on isn't possible.
LdrDat2Obj2: no apparent batch process
Toby Nelson/TobyLobster's blender importer: seems to work well, but only allows one .dat to import at a time - that's not workable with 14,000 parts.
Matthew Morrison's blender importer: Crashes every time I try to import a .dat file. I posted more details about the crash in his thread:
https://forums.ldraw.org/thread-24153.html
LDView: no apparent batch process
Stud.IO: no way I can see to create a file that contains each brick once.
If I could get the ldraw parts into any conventional 3D model format I would be able to batch convert the results into something game engines can use, including obj, fbx, stl, dae, and -probably- usd.
What about using LDView on the command line and build a batch processing aroudn it?
(2021-08-22, 12:45)KristyB Wrote: [ -> ]LDView: no apparent batch process
LDView itself does not support globbing (*.dat, for example), but it can be called from a batch file that does. It supports command line exports to POV, STL (monochrome output), and 3DS. Please search for ExportFiles, SaveExportType, and ExportSuffix in LDView's help file for instructions on using it.
(2021-08-22, 21:39)Travis Cobbs Wrote: [ -> ]LDView itself does not support globbing (*.dat, for example), but it can be called from a batch file that does. It supports command line exports to POV, STL (monochrome output), and 3DS. Please search for ExportFiles, SaveExportType, and ExportSuffix in LDView's help file for instructions on using it.
Thank you both for the suggestion!
Iterating through a list that both skips numbers and has arbitrary letters sprinkled in with the numbers seems a bit daunting, and my experience with bats file is less than rudimentary. I'm also not sure what globbing is in this context. It might take me a good while, so if anyone has other suggestions while I tinker with it I'd be glad to hear them too.
It occurs to me I can also use Python in in blender to script the import/export process, maybe? I'm already pretty familiar with Python, and Toby Nelson's .dat import options would allow me to automate the high-poly making process for a lot of the Bricks. I am going to try this route first before looking at LDView.
(2021-08-23, 11:22)KristyB Wrote: [ -> ]Thank you both for the suggestion!
A simple batch file like
for %%f in (*.dat) do call ldview....
Should do.
Please note, I did not try this and you would need to specify the filename (especially the ecport name) also in the ldview command string.
Add an 'echo'to see the progress
(2021-08-22, 12:45)KristyB Wrote: [ -> ]I'm trying to build a library of game-ready parts for use in video games, and would like a library of low-poly bricks to fall back on for bricks I have not yet converted by hand. I've dug around and tried a few methods so far, but all have failed to work.
Matthew Morrison's blender importer: Crashes every time I try to import a .dat file. I posted more details about the crash in his thread: https://forums.ldraw.org/thread-24153.html
Are you still getting the crash? I've pushed a few updates since you posted the error report.
i got it to work with this:
@echo off
set sourcedir=F:\ldview iter test\parts
set exportdir=F:\ldview iter test\stlexp
for %%f in ("%sourcedir%\*.dat") do (
"E:\LEGO\LDraw suite\LDView\LDView64.exe" -ExportFile="%exportdir%\%%~nf.stl" "%%f"
but for some reason its exporting parts super small
(2023-06-23, 5:34)Kuemmerle Wrote: [ -> ]i got it to work with this:
@echo off
Try doing an STL export from the LDView UI, then go to the export options and check the units. Choose and appropriate unit and export to verify. The command line should use the most recently selected units from LDView UI.
(2023-06-23, 17:13)Travis Cobbs Wrote: [ -> ]Try doing an STL export from the LDView UI, then go to the export options and check the units. Choose and appropriate unit and export to verify. The command line should use the most recently selected units from LDView UI.
That worked, thanks so much.
after making that, i also made this python script to rename everything if u want:
import os
import re
import shutil
def rename_files(dir_path):
print(f"Looking for .dat files in {dir_path}...")
for filename in os.listdir(dir_path):
print(f"Found file: {filename}")
if filename.endswith('.dat'):
filepath = os.path.join(dir_path, filename)
with open(filepath, 'r') as file:
first_line = file.readline()
file.close() # Manually closing the file after reading the first line
match = re.match(r"^0\s+(.*)", first_line)
if match:
part_name = match.group(1).strip()
part_name = part_name.replace('/', '-') # Replace forward slashes with hyphens
part_name = re.sub(r'[<>:"|?*]', '', part_name) # Remove illegal characters
part_name = part_name.replace('(', '').replace(')', '') # Remove parentheses
new_name = part_name.replace(' ', '_') + f'_id-{filename[:-4]}'
new_name = (new_name[:97] + '...') if len(new_name) > 100 else new_name # Ensure filename is not too long
new_name += '.dat'
new_path = os.path.join(dir_path, new_name)
print(f"Old name: {filename}")
print(f"First line: {first_line.strip()}")
print(f"Extracted part name: {part_name}")
print(f"New name: {new_name}")
try:
shutil.copy2(filepath, new_path) # Copy the file
os.remove(filepath) # Remove the old file
except Exception as e:
print(f"Failed to rename {filepath} to {new_path}. Error: {str(e)}")
# Use the function on your directory
rename_files('F:\\ldview iter test\\parts')
This just reads the metadata in the.dat files before converting to stl and appends it to the file name
