2021-06-18, 17:51
This is a master thread for problems with the WebGL based model viewer used by both the PT and the model viewer on the main site.
(2021-06-18, 17:51)Orion Pobursky Wrote: [ -> ]This is a master thread for problems with the WebGL based model viewer used by both the PT and the model viewer on the main site.
(2022-06-01, 14:53)Orion Pobursky Wrote: [ -> ]I've noticed that there are a handful of parts on the PT that are refusing to load:
https://www.ldraw.org/cgi-bin/ptdetail.c...s/2655.dat
Not sure if this extends to the Model Viewer. Further troubleshooting is required. If you find any others that don't load, please post them as a reply to this post.
(2022-06-02, 1:43)Orion Pobursky Wrote: [ -> ]I've fixed the issue with the above part. This has to do with the way studs are loaded in buildinginstructions.js. There may be other files with similar issues. Please report hem here if you encounter them.
<!-- buildinginstructions.js optional libraries: Generator.js for quick creation of some primitives. Required for studs.js which can create customized studs. StudioTexmap.js allows for Studio 2.0-created files -->
<script src="js/LDRGenerator.js"></script>
<script src="js/LDRStuds.js"></script>
<script src="js/StudioTexmap.js"></script>(2022-06-05, 7:00)Lasse Deleuran Wrote: [ -> ]Are you also using LDRGenerator.js? If so, then they should have worked without the fix. And in that case, there is a bug which has to be remedied.
LDR.Studs.makeGenerators('', LDR.Options.studHighContrast, LDR.Options.studLogo);(2022-06-06, 20:15)Magnus Forsberg Wrote: [ -> ]Here is another one that doesn't load
https://www.ldraw.org/cgi-bin/ptdetail.c...709p0h.dat
(2022-06-06, 21:06)Magnus Forsberg Wrote: [ -> ]Yes, sorry.
The webGL loads, but there is no preview image in the corner and no dependencies on the part page.
