While making a model using part 57783.dat in transparent I noticed a strange reddish line artifact when looking at it a certain angle (in LDCad).
Is that normal or is it an error in the part or rendering in LDCad?
Looking at it from another angle it is gone.
attachment=6588]
(2021-06-17, 14:04)Jaco van der Molen Wrote: [ -> ]Is that normal or is it an error in the part or rendering in LDCad?
No, there are some red condlines in the subfile, 57783s01. It's an error.
(2021-06-17, 15:25)Magnus Forsberg Wrote: [ -> ]No, there are some red condlines in the subfile, 57783s01. It's an error.
For what it's worth, they show up in red in LDView also. If you enable "Show all" for conditional lines in LDView, you can easily see that there are two red ones on each side.
(2021-06-17, 20:58)Travis Cobbs Wrote: [ -> ]For what it's worth, they show up in red in LDView also. If you enable "Show all" for conditional lines in LDView, you can easily see that there are two red ones on each side.
OK, @Magus: can you correct this?
(2021-06-18, 7:12)Jaco van der Molen Wrote: [ -> ]OK, @Magus: can you correct this?
When it is recycled, the area in question shall be replaced by a CYLI
PS, interestingly this is a pretty old part and the issue just gets noticed now :-)
Done, and in the mail to Admin.
