2021-05-24, 9:44
Hey,
this version uses a different configuration file.
Therefore, it will be necessary to reset all your custom LDPE settings.
What you can do as a workaround:
In total, today's release adresses about 100 different code issues.
Changelog:
(3 new features and 6 bug fixes)
System Requirements:
Minimum System Requirements:
- run two LDPE instances in parallel (0.8.53 + 0.8.52) and open both option menus to sync the settings manually.
- take screenshots from your options menu entries in 0.8.52 before installing 0.8.53.
Changelog:
- ...benefit from about 100 different optimizations to LDPEs code base (I added 180000 lines and deleted 185000 lines of code since the last release).
- ...benefit from a new, more robust and secure method which loads and saves LDPEs configuration file.
- ...get improved hints and tips for the startup dialog (seen on first program start).
- Undo / Redo broke the 3D model if the file ended with empty lines or contained duplicated empty line groups.
- The calculated colour for transparent textures was too dark. (OpenGL 2.0)
- On MacOS X it was not possible to reassign a shortkey, because the dialog window had not the required focus for detecting the keyboard input.
- Avoided obvious divisions by zero on "zoom to fit" with empty models and by scaling a zero-height font with Txt2Dat.
- The 3D editor freezed by an BFC INVERTNEXT without a following TYPE 1 reference line.
- "Make subpart from 3D selection" duplicated "0 BFC INVERTNEXT" meta commands.
- Download the zip-Archive
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
