2021-05-14, 10:19
Hey,
I recieved a mail from Willy and transformed it into a new LDPatternCreator version.
Download and install the latest LDPatternCreator release directly from sourceforge.net.
Any previous version should be uninstalled first. Your program configuration will be preserved.
Change log:
New features:
Fixed bugs:
As always, I included a short readme.htm in the installation directory.
Cheers & Leg Godt
Nils
Change log:
New features:
- Included the latest #-#tang primitives (1-16tang.dat, 1-8tang.dat, 1-4tang.dat, 48\1-16tang.dat, 48\1-8tang.dat).
Fixed bugs:
- "Add Vertex" was not compatible with the "Create a Spline..." feature.
- Version 1.7.2 triggered a false alert on Windows Defender. I had to increase the version number and re-build it.
Quote:Bug-Detail:
- Select "Add Vertex [A]"
- Set a vertex. Watch out for the small coordination windows in the bottom right-hand corner
- Select "Add Primitive [F7]... Create a Spline..."
- Click to add the spline starting point
- Click to set the first direction of the spline
- Click to add the next point
- Click to set the next direction
- You CANNOT click to apply the segment count because the "Vertex-Data" is still there hiding the segment count window underneath.
Cheers & Leg Godt
Nils
