Full Version: [LDPatternCreator] Release 1.7.3 (new tangent primitives / bugfix)
Hey,
I recieved a mail from Willy and transformed it into a new LDPatternCreator version.
Download and install the latest LDPatternCreator release directly from sourceforge.net.
Any previous version should be uninstalled first. Your program configuration will be preserved.
Change log:
New features:
  • Included the latest #-#tang primitives (1-16tang.dat, 1-8tang.dat, 1-4tang.dat, 48\1-16tang.dat, 48\1-8tang.dat).
Fixed bugs:
  • "Add Vertex" was not compatible with the "Create a Spline..." feature.
  • Version 1.7.2 triggered a false alert on Windows Defender. I had to increase the version number and re-build it.
Quote:Bug-Detail:
  •     Select "Add Vertex [A]"
  •     Set a vertex. Watch out for the small coordination windows in the bottom right-hand corner
  •     Select "Add Primitive [F7]... Create a Spline..."
  •     Click to add the spline starting point
  •     Click to set the first direction of the spline
  •     Click to add the next point
  •     Click to set the next direction
  •     You CANNOT click to apply the segment count because the "Vertex-Data" is still there hiding the segment count window underneath.
As always, I included a short readme.htm in the installation directory.
Cheers & Leg Godt
Nils
(2021-05-14, 10:19)Nils Schmidt Wrote: [ -> ]
Works as expected. You were really fast this time but I was faster and did the job in LDPE. Part is already on the PT
https://www.ldraw.org/cgi-bin/ptdetail.c...03566b.dat
Why can't I see anything to select? I'm guessing it ought to be here.
[attachment=6487]
(2021-05-14, 10:19)Nils Schmidt Wrote: [ -> ]Fixed bugs:
What was the problem exactly?
(2021-05-14, 14:36)Magnus Forsberg Wrote: [ -> ]Why can't I see anything to select? I'm guessing it ought to be here.
Yeah... same thing here!
...and something I miss for a long time: possibility to select several primitives together to be able to act on them (cut/paste, scale, rotate, etc...)
Please uninstall the program first and then re-install it. This will solve the problem.
(2021-05-14, 14:54)Nils Schmidt Wrote: [ -> ]Please uninstall the program first and then re-install it. This will solve the problem.
It does... thanks!
(2021-05-14, 14:45)Philippe Hurbain Wrote: [ -> ]What was the problem exactly?
Bug details / how to reproduce:
  •     Add a vertex. Watch out for the small coordination windows in the bottom right-hand corner
https://forums.ldraw.org/thread-23468-po...l#pid34696
Since 19th of May MS-Defender detects LDPatternCreator version 1.7.2 as a malicious executable.
I had to do a rebuild with the version number 1.7.3.
(2021-05-19, 21:18)Nils Schmidt Wrote: [ -> ]Since 19th of May MS-Defender detects LDPatternCreator version 1.7.2 as a malicious executable.
Hi Nils,
I've just attempted to update my copy of LDPC with the latest 1.7.3 and it is also triggering the MS-Defender as well as Norton360, highlighting "WS.Reputation.1" as the trigger.
Cheers
(2021-09-13, 23:23)ShireBrickz.com Wrote: [ -> ]Hi Nils,
Cheers
I can't reproduce the alert on virustotal.com and on my machine.
Here is the virustotal.com report (with two false postive scans):
https://www.virustotal.com/gui/file/615f...4d/details
