2021-05-11, 4:00
Regarding the Mursten-era door (u8012) and windows (u8019–u8024):
The geometry of these parts is not quite right, and leads to collisions when the tabs are interlocked as intended. I propose this modification, which avoids these collisions, and also those that arise by placing the tab behind a neighboring brick (as seen here). But the real geometry may be a slightly thicker tab that fills the slot better, with the part itself being slightly less than a brick-width in Z (so maybe 18 LDU or so), relying on the part's flexibility to fit behind or in front of a neighboring brick.
This revision also subfiles the tab, for brevity's sake. I use u8021 as an example, but all seven parts would be affected.
