Full Version: I am not able to find this part.
Pages: 1 2
(2021-06-25, 12:36)Philippe Hurbain Wrote: [ -> ]Done from photos so probably not perfect, but should do the trick...
https://www.ldraw.org/cgi-bin/ptdetail.c...33011b.dat
(also made the milk bottle... https://www.ldraw.org/cgi-bin/ptdetail.c...33011a.dat)
(edit: and the jar... https://www.ldraw.org/cgi-bin/ptdetail.c...33011c.dat)
Hey thanks! Looks very good to me. I imported the wine bottle .dat in PartDesigner and got a Parts Not Found error message. Only the cap and inner/bottom surface of the bottle load in. Would you recommend adding it manually to Stud.io program data?
(2021-06-26, 1:25)Nathan Feist Wrote: [ -> ]Hey thanks! Looks very good to me. I imported the wine bottle .dat in PartDesigner and got a Parts Not Found error message. Only the cap and inner/bottom surface of the bottle load in. Would you recommend adding it manually to Stud.io program data?
You can add unofficial parts to the CustomParts folder. Do a forum search for instructions. That's said, I would recommend not using Stud.uo and using LDCad instead since it's more LDraw compatible. .
(2021-06-26, 1:25)Nathan Feist Wrote: [ -> ]Only the cap and inner/bottom surface of the bottle load in.
You must also download the needed subpart, and place it in the correct folder.
(2021-06-26, 2:47)Orion Pobursky Wrote: [ -> ]You can add unofficial parts to the CustomParts folder. Do a forum search for instructions. That's said, I would recommend not using Stud.uo and using LDCad instead since it's more LDraw compatible. .
Thanks, I got it! I had to create an \s folder for the subpart Magnus pointed out since none of the custom parts I made have subparts. BTW I recognize your name since I saved some photos you took of things I exhibited at Brickfair 2008.
Pages: 1 2
