Full Version: Minor changes to the Official Library Spec
Pages: 1 2 3 4
Based on feedback, I'd like to proposed a few minor changes to the Official Library Spec:
Clarification to Sticker Geometry:
- For stickers printed on a transparent medium, the type 1,3, or 4 lines that comprise the pattern shall be preceded by a 0 BFC NOCLIP statement and ended by a 0 BFC CLIP statement
- The pattern should be oriented such that the top of the pattern aligns with the +Z axis. Exceptions to this rule may be made on a case by case based.
Claification to Sticker Shortcuts:
- Require a !KEYWORDS entry with text similar to Pattern !KEYWORDS Entry:
A sticker shortcut should, at a minimum include at least one !KEYWORDS entry in the form of Set <set number> where <set number> is the number of an official LEGO set in which that pattern appears. Only one set need be listed but more can be if desired.[/b]
(2021-04-26, 20:50)Orion Pobursky Wrote: [ -> ]Based on feedback, I'd like to proposed a few minor changes to the Official Library Spec:
I approve, with a minor change to the second proposal: "... in which that pattern appears." --> "... in which that sticker appears."
(2021-04-26, 20:50)Orion Pobursky Wrote: [ -> ]Clarification to Sticker Geometry:
Why should we be forced to add a BFC NOCLIP in all stickers on a transparent medium?
I can see a need if the transparent sticker is intended to be on a tranparent part, like a glass window, but not if it's only used on solid coloured bricks. If the idea is that a user might want to have any sticker on a transparent part visible from behind, then why don't we have all patterns, on all parts, in a BFC NOCLIP? I don't see why a print on a transparent sticker should be treated differently than a printed brick.
(2021-04-26, 20:50)Orion Pobursky Wrote: [ -> ]- For stickers printed on a transparent medium, the type 1,3, or 4 lines that comprise the pattern shall be preceded by a 0 BFC NOCLIP statement and ended by a 0 BFC CLIP statement
Does this mean that the unprinted top surface is not allowed to be within the BFC NOCLIP section?
(2021-04-27, 16:32)Magnus Forsberg Wrote: [ -> ]If the idea is that a user might want to have any sticker on a transparent part visible from behind, then why don't we have all patterns, on all parts, in a BFC NOCLIP?
I'm not a fan of the proposed rule as I think it is too use specific but it was requested to I added it.
I also had the same thought as above. One of the major points of LDraw is that parts can be in any color. Maybe we should update parts as they are recycled. Or, better yet, just revise the BFC spec so that non-color 16 and 24 lines are excluded from BFC (actually, now that I think about it, that might be too broad).
I'm willing to live with a small quirk of rendering for the sake of simplicity.
(2021-04-27, 16:32)Magnus Forsberg Wrote: [ -> ]Why should we be forced to add a BFC NOCLIP in all stickers on a transparent medium?
To be in sync with the specs for patterns on transparent parts and not have yet another exception of a general rule?
Since there were no more comments for 3 months it should be added to the specs.
(2021-07-21, 11:59)Willy Tschager Wrote: [ -> ]Since there were no more comments for 3 months it should be added to the specs.
I issued a call for votes:
https://forums.ldraw.org/thread-24745.html
Why do this text say:
Quote:shall be preceded by a 0 BFC NOCLIP statement and ended by a 0 BFC CLIP statement
when the bfc page say:
https://www.ldraw.org/article/415
Quote:affects all lines following the CLIP/NOCLIP option, either until the end of the current file or another CLIP/NOCLIP option is encountered.
Why should the sticker be forced to be ended by a 0 BFC CLIP, when the other rule say end of file ?
Is it correct to end a file without a 0 BFC CLIP statement, if you have used a 0 BFC NOCLIP?
(2021-07-21, 21:45)Magnus Forsberg Wrote: [ -> ]Why should the sticker be forced to be ended by a 0 BFC CLIP, when the other rule say end of file ?
If the pattern geometry is at the end of the file, then the 0 BFC CLIP is indeed not needed. It is however required if any non-pattern geometry follows the pattern geometry. So the wording should be updated to reflect that.
(2021-07-21, 21:59)Travis Cobbs Wrote: [ -> ]If the pattern geometry is at the end of the file, then the 0 BFC CLIP is indeed not needed. It is however required if any non-pattern geometry follows the pattern geometry. So the wording should be updated to reflect that.
Agreed. Could you please update the wording and also rework the requirement of a set number in the KEYWORDS for both stickers and sticker shortcuts?
Pages: 1 2 3 4
