I'm using the 3-16ndis.dat primitive in the part I'm working on (35103).
In fact I had to slice a 2-4ndis, so I replaced it by two 3-16ndis and the two quads I get using SlicerPro.
The matter is that, there's a realy small gap between the 3-16ndis primitive and each quad. But this gap disappears when I inline the primitive with LDDP, so I deduced it's a matter of precision using SlicerPro. The problem is that even with a better precision the gap is still here.
I've the same problem with 3-8cyli.dat for the vertical part.
So my question is : should I keep the primitive and the gap, or should I inline the primitive to close the gap ?
Or maybe there's a third way I didn't thought about...
It's difficult to give good advice without seeing the data - can you share the file - or better another simplified one showing the problem?
(2021-04-21, 8:03)Philippe Hurbain Wrote: [ -> ]It's difficult to give good advice without seeing the data - can you share the file - or better another simplified one showing the problem?
thank you for your answer, here it is : (I colored the primitives in green and the problematic quads in red, the vertical ones are realy thin)
0 // 140-144
1 16 2.5 144 5.25 2 0 0 0 -1 0 0 0 -2 2-4ndis.dat
1 16 2.5 144 5.25 2 0 0 0 1 0 0 0 -2 2-4edge.dat
1 16 2.5 144 5.25 2 0 0 0 -4 0 0 0 2 4-4cyli.dat
0 // 144
3 16 0.5 144 5.25 0.649 144 6 0.5 144 6
3 16 4.351 144 6 4.5 144 5.25 4.5 144 6
2 24 0.649 144 6 0.5 144 6
2 24 0.5 144 5.25 0.649 144 6
0 // 144-148
1 2 2.5 148 5.25 1.848 0 -0.765 0 -4 0 0.765 0 1.848 3-8cyli.dat
4 4 0.649 148 6 0.6522 148 6.0154 0.6522 144 6.0154 0.649 144 6
4 16 0.649 148 6 0.5 148 6 0.5 144 6 0.649 144 6
4 4 4.351 148 6 4.3478 148 6.0154 4.348 144 6.015 4.351 144 6
4 16 4.351 148 6 4.5 148 6 4.5 144 6 4.351 144 6
2 24 0.649 148 6 0.649 144 6
2 24 4.351 148 6 4.351 144 6
0 // 148
1 2 2.5 148 5.25 0 0 -2 0 1 0 2 0 0 3-16ndis.dat
0 0.6522 148 6.0154 <----------------------------first problematic vertex
1 2 2.5 148 5.25 0 0 2 0 1 0 2 0 0 3-16ndis.dat
0 4.3478 148 6.0154 <----------------------------second problematic vertex
1 16 2.5 148 5.25 1.848 0 -0.765 0 1 0 0.765 0 1.848 3-8edge.dat
4 4 0.5 148 6 0.5 148 7.25 0.6522 148 6.0154 0.649 148 6
4 4 4.351 148 6 4.3478 148 6.0154 4.5 148 7.25 4.5 148 6
2 24 0.6490196 148 6 0.6522 148 6.0154
2 24 0.6490196 148 6 0.5 148 6
2 24 4.351 148 6 4.3478 148 6.0154
2 24 4.351 148 6 4.5 148 6
2 24 4.351 144 6 4.5 144 6
2 24 4.351 144 6 4.5 144 5.25
Hi
I would replace the
with
1 2 2.5 148 5.25 0 0 -2 0 -4 0 2 0 0 3-16cyli.dat
1 2 2.5 148 5.25 0 0 2 0 -4 0 2 0 0 3-16cyli.dat
so you avoid a 67.5 deg rotated part (3-8clyi) touching a non-rotated one (ndis)
I cannot see the issue with the inlining, I am using LDPE, though.
I would then move the two quads
to touch the 3-16 ndis
4 16 .6523477 148 6.0157893 .5 148 6.0154 .5 144 6.0154 .6522 144 6.0154
4 16 4.348 148 6.015 4.5 148 6.0154 4.5 144 6.0154 4.348 144 6.015
I do not know where in the part (WHAT a part...) this sits, but the 0.0154 LDU should be possile to accommodate without any visual imparment, if you need them to be at Z=6 then I would even consider the quads like this
4 16 .6523477 148 6.0157893 .5 148 6 .5 144 6 .6522 144 6.0154
4 16 4.348 148 6.015 4.5 148 6 4.5 144 6 4.348 144 6.015
Touching the 3-8ndis at 6.0154 and the other side at 6
Gerald
(2021-04-21, 11:42)Gerald Lasser Wrote: [ -> ]Hi
I would replace the
with
Gerald
Thank you for your help, replacing the 3-8cyli by 2 3-16cyli helped a lot. I check all the coordinates (some fourth decimal were incorect) and it seems to be ok for now.
