Full Version: Minifig Hat Bicorner with Black Admiral Pattern - 2528px2
Hi I'm looking for
Minifig Hat Bicorner with Black Admiral Pattern - 2528px2.
Tomasz
here you are
https://www.ldraw.org/cgi-bin/ptdetail.c...528p32.dat
don't forget the subfile
Taking the discussion form the part s\2528s01 to the forum
Magnus, here's my proposal for the rework.
- based on the Unity/LDD geometry
- measurements confirmed with calipers
- I broke down the LDD geometry and refined it a bit, hopefully not adding too many surfaces.
What changed?
- Plume attachment point
- Top width increased
- Bottom width decreased
- Rounded ends
What is pending?
- Runded gap in the middle
Please check the outer surfcase!
Thanks
Gerald
I think it looks good.
But I prefer the simpler ldd outer surface mesh. The edge on yours is better, though.
It needs a full 180 rotation, the plume is allways on the left side.
And the rounded ends should be more flat.
4 9 -26.25 7.5 -3.33 -26.012 4.623 -2.95 -26.012 4.623 2.95 -26.25 7.5 3.33
2 11 -26.012 4.623 2.95 -26.25 7.5 3.33
2 11 -26.012 4.623 -2.95 -26.25 7.5 -3.33
Here's a proposal in the middle
LDD some 30+ surfaces
Surface: 65 surfaces
Redone: Surface-2 44 surfaces
(2021-04-20, 12:45)Gerald Lasser Wrote: [ -> ]Here's a proposal in the middle
Looks to be a good compromise!
(2021-04-20, 14:20)Philippe Hurbain Wrote: [ -> ]Looks to be a good compromise!
I like it too.
A new version of the hats, and a new print, is now done.
[attachment=6385]
https://www.ldraw.org/cgi-bin/ptscan.cgi?q=bicorne
Small request, big results!
A request for the Admiral's Hat resulted in the correction of the geometry and making all patterns available!
Magnus is working on the last one, soe here's the Family Picture of today with one member on the way:
[attachment=6401]
Thanks
And now the last version is on the Part Tracker.
https://www.ldraw.org/cgi-bin/ptscan.cgi...ope=header
https://www.ldraw.org/cgi-bin/ptpatterns.cgi?p=2528a
Here's a summary of all the files
[attachment=6408]
