Could someone create a part for me that is a flat square with a texture map applied? I don't understand the syntax and could use an example part to look at. Thanks!!
(2021-04-13, 18:39)Michael Horvath Wrote: [ -> ]Could someone create a part for me that is a flat square with a texture map applied? I don't understand the syntax and could use an example part to look at. Thanks!!
There are plenty of examples on the PT and official lib. Here's a good one:
https://www.ldraw.org/cgi-bin/ptdetail.c...41502a.dat
If you just want to make flat sticker parts, you could use my simple generator.
http://www.melkert.net/test/stickerGen.html
