2021-03-24, 17:41
I created these primitives with the purpose to avoid the rotation of the corresponding ones. I hope they can be approved. If not, I send an email to the PT Admin for deletions.
(2021-03-24, 17:41)Javier Orquera Wrote: [ -> ]I created these primitives with the purpose to avoid the rotation of the corresponding ones. I hope they can be approved. If not, I send an email to the PT Admin for deletions.
(2021-03-24, 17:41)Javier Orquera Wrote: [ -> ]I created these primitives with the purpose to avoid the rotation of the corresponding ones. I hope they can be approved. If not, I send an email to the PT Admin for deletions.I can see the rationale, as I often split round prims to avoid the need to rotate them, but the number of needed variants is so high (and become unmanageable for hires prims!!!)
(2021-03-24, 17:59)Travis Cobbs Wrote: [ -> ]I will say right now that I'm not going to support these in LDView's primitive substitution. As such, the only way that I feel they would be acceptable is if they are shortcuts to the existing cyli and cylo primitives. Furthermore, they appear to be rotated 135 degrees, not 45 degrees.
(2021-03-24, 19:14)Magnus Forsberg Wrote: [ -> ]Forcing them to be an alias of the regular primitives would create the very rotation they intend to avoid.
(2021-03-24, 22:03)Travis Cobbs Wrote: [ -> ]If they're doing it for performance reasons, then they are misguided, since the matrix math is exactly the same with or without the rotation. I agree with Philo, though, that there are just two many possible ways to rotate things, and so we should completely avoid rotated primitives.
(2021-03-24, 22:41)Magnus Forsberg Wrote: [ -> ]But if an author is rounding of the values of a rotated primitive in his design, it will introduce a miscalculation, and cause thin, hairline gaps. Right?
(2021-03-25, 1:19)Travis Cobbs Wrote: [ -> ]then it might be better to relax the 3-decimal-place restriction for transformation matrices in parts.It is not a restriction but a suggession: "In general, three decimal places are sufficient for parts". All the parts I made for years have 5 digits transformation matrices, because I got too many problems with just 3. Even 4 causes problems.
(2021-03-25, 8:32)Philippe Hurbain Wrote: [ -> ]It is not a restriction but a suggession: "In general, three decimal places are sufficient for parts". All the parts I made for years have 5 digits transformation matrices, because I got too many problems with just 3. Even 4 causes problems.
(2021-03-25, 20:40)Magnus Forsberg Wrote: [ -> ]I think the conclusion already is that this type of rotation inside a primitive is a no go.
Use mirrored and divided primitives instead. Your suggested a3-8cyli should be created like this instead:
1 12 0 0 0 0 0 -1 0 1 0 1 0 0 3-16cyli.dat
1 12 0 0 0 0 0 1 0 1 0 1 0 0 3-16cyli.dat
