2021-03-17, 14:59
thanks to Travis' help my batch pov generation script works fine.
But, I encountered several issues when rendering some parts.
for exemple :
So I investigate a bit about 1-16ring9.dat.
First of all, and obviously, the primitive is in my "ldraw\p\" directory, andthe 14639p01dat part opens without errors in LDview.
Then, I thought that some config file like LGEO.xml or LGDefs.inc were involved, but they do not have anything to do with that (if I'm right).
So I took a look at the buggy files and the integration of primitives in pov files.
If I understand the error message correctly, LDX_1_dash_16ring9_dot_dat_in_part has not been defined before, not like the other primitives involved in that part.
So, at some point, some lines like those for 1-16ri60.dat :
should have been written in the pov file but aren't. And I suppose that I can't choose randoms coordinates to solve the problem.
So my question is : do the problem come from a config file I didn't think about, or is it a export bug ?
I've the problem with other primitives on other parts.
for exemple :
"d:\lego\python\data\renders\0\14639p01.pov" line 1117: Parse Error: Expected 'object', undeclared identifier 'LDX_1_dash_16ring9_dot_dat_in_part' found instead
Render failed
#declare LDX_48_slash_1_dash_16ri60_dot_dat_in_part = disc // Ring 0.0625
<0,0,0>,<0,1,0>,61,60
clipped_by
plane
<0,0,-1>,0
plane
<-0.38268343236508972627,0,0.92387953251128673848>,0
#declare LDX_48_slash_1_dash_16ri60_dot_dat = disc // Ring 0.0625
clipped_by
plane
<0,0,-1>,0
plane
