2021-03-15, 0:15
[attachment=6152]
I'm using LDCad 1.6d, working on an animation, and have a baffling problem. I can recreate the problem using Roland's original basic animation demo on YouTube:
As soon as I launch the LUA script, the Axle1 sub-model jumps to a new position on the first frame. It also loses the 13° rotation that allowed its 14 tooth gear to mesh correctly with the Axle2 gear. See aniDemoMove.png
Then using Roland's setRotate(angle, 1, 0, 0) the sub-model rotates around the wrong axis. See aniDemoWrongAxis.png
Changing setRotate() to "angle, 0, 0, 1" fixes the wrong axis problem so the sub-model rotates around the correct axis, but I can't find any way to keep the sub-model from jumping to the new position and losing its 13° adjustment.
I've done other animations (which still work) and have never seen this problem. Now it's happening to every new model I make!
Model:
![[Image: aniDemoModel.png]](https://www.bricksafe.com/files/Walt.White/animation-demo/aniDemoModel.png)
Move:
![[Image: aniDemoMove.png]](https://www.bricksafe.com/files/Walt.White/animation-demo/aniDemoMove.png)
Wrong axis:
![[Image: aniDemoWrongAxis.png]](https://www.bricksafe.com/files/Walt.White/animation-demo/aniDemoWrongAxis.png)
LDR file:
LUA code:
Model:
Move:
Wrong axis:
LDR file:
0 FILE main.ldr
0 Name: animationDemo
0 Author: LDCad
0 !LDCAD SCRIPT [source=animationDemo.lua]
1 14 0 0 0 1 0 0 0 1 0 0 0 1 3702.dat
1 14 50 0 -30 0 0 1 0 1 0 -1 0 0 3700.dat
1 14 -70 0 -30 0 0 1 0 1 0 -1 0 0 3700.dat
1 14 -10 0 -30 0 0 1 0 1 0 -1 0 0 3700.dat
1 14 0 0 -60 1 0 0 0 1 0 0 0 1 3702.dat
1 14 -70 -8 -30 0 0 1 0 1 0 -1 0 0 3710.dat
1 14 -10 -8 -30 0 0 1 0 1 0 -1 0 0 3710.dat
1 14 50 -8 -30 0 0 1 0 1 0 -1 0 0 3710.dat
1 14 50 24 -30 0 0 1 0 1 0 -1 0 0 3710.dat
1 14 -10 24 -30 0 0 1 0 1 0 -1 0 0 3710.dat
1 14 -70 24 -30 0 0 1 0 1 0 -1 0 0 3710.dat
1 16 -23 10 -30 0 0 1 0 1 0 -1 0 0 Axle2.ldr
1 14 50 -16 -30 0 0 1 0 1 0 -1 0 0 3023.dat
1 14 50 -40 -30 0 0 1 0 1 0 -1 0 0 3700.dat
1 16 60 -30 -30 1 0 0 0 0.99 0.139 0 -0.139 0.99 Axle3.ldr
1 16 -40 10 -80 -0.974 -0.225 0 -0.225 0.974 0 0 0 -1 Axle1.ldr
0 FILE Axle1.ldr
0 Author: LDraw
1 71 0 0 0 1 0 0 0 1 0 0 0 1 3736.dat
1 0 0 0 -50 0 0 -1 0 1 0 1 0 0 3706.dat
1 71 0 0 -67 -1 0 0 0 1 0 0 0 -1 4143.dat
1 71 0 0 -99.997 1 0.001 0 -0.001 1 0 0 0 1 3713.dat
1 71 -30 0 12 0 0.139 -0.99 0 0.99 0.139 1 0 0 3749.dat
0 FILE Axle2.ldr
0 Author: LDraw
1 71 0 0 0 1 0 0 0 1 0 0 0 1 4143.dat
1 0 0 0 53 0 0 1 0 1 0 -1 0 0 3706.dat
1 71 0 0 93 1 0 0 0 1 0 0 0 1 3647.dat
0 FILE Axle3.ldr
0 Author: LDraw
1 71 0 0 0 1 0 0 0 1 0 0 0 1 3749.dat
1 71 10 0 0 0 0 1 0 1 0 -1 0 0 3648.dat
LUA code:
function register()
local ani=ldc.animation('animationDemo')
ani:setLength(20)
ani:setEvent('frame', 'onFrame')
end
function onFrame()
local ani=ldc.animation.getCurrent()
local mainSf=ldc.subfile()
local ori=ldc.matrix()
local angle=720*ani:getFrameTime()/ani:getLength()
local ax1=mainSf:getRef('Axle1.ldr')
ori:setRotate(angle, 0, 0, 1)
ax1:setOri(ori)
end
register()
