2021-02-23, 21:11
Hello.
I'm trying to use LDView command line to do batch pov generation. I have 2 problems
the first one is that the pov file I get using command line with ExportFile is not the same I get using the same command line and manual export.
Case 1 :
vs :
Case 2 :
Of course, the second line give me exactly what I want in the LDView window.
they're only two differences :
the first line of the header is not the same (it's not a problem, but it's strange)
Case 1 :
vs :
Case 2 :
the camera settings are wrong in case 2 :
Case 1 :
vs :
Case 2 :
Obviously, in the first case, the camera is too close and my renders are cropped. I bypass the problem by tweaking LDXCamAspect and angle, but the result is not what I want and what I've set up. I can go with it for now, but it's strange.
The other problem is that I'm not able to use the -commandLinesList functionnality.
I've created a file named commandlist.txt :
My command line is :
LDview just pop up like usualy, asking me to open a file. I'm lost.
Case 1 :
D:\Installations\LDRAW\LDView64\LDView64.exe D:\LEGO\Python\data\3001.ldr -DefaultLatitude=20 -DefaultLongitude=45 -WindowWidth=504 -WindowHeight=563 -ExportFile=D:\LEGO\Python\data\3001.pov
vs :
Case 2 :
Case 1 :
// Generated By: LDView Copyright (C) 2018 Travis Cobbs & Peter Bartfai
Case 2 :
// Generated By: LDView 4.3 Copyright (C) 2018 Travis Cobbs & Peter Bartfai
Case 1 :
#declare LDXCameraLoc = < 447.158142,-351.187286,-446.14975 >; // Camera Location vector
#declare LDXCameraLookAt = < 4.58077876387164906191,10.17561232900345657981,-3.57247258550586366255 >; // Camera look-at point vector
#declare LDXCameraSky = < -0.35355329881115843405,-0.86602543005723520153,0.35355341802042911103 >; // Camera sky vector (<0,-1,0> will usually work for standard "up")
Case 2 :
#declare LDXCameraLoc = < 707.842224,-354.348816,-707.842224 >; // Camera Location vector
#declare LDXCameraLookAt = < 2.24497200047949263535,8.84444866651756456122,-2.24497200047949263535 >; // Camera look-at point vector
#declare LDXCameraSky = < -0.24184478580022841787,-0.93969260886871053273,0.24184478580022841787 >; // Camera sky vector (<0,-1,0> will usually work for standard "up")
Common: -DefaultLatitude=20 -DefaultLongitude=45 -WindowWidth=504 -WindowHeight=563
D:\LEGO\Python\data\3001.ldr -ExportFile=D:\LEGO\Python\data\3001.pov
D:\LEGO\Python\data\3002.ldr -ExportFile=D:\LEGO\Python\data\3002.pov
D:\LEGO\Python\data\3003.ldr -ExportFile=D:\LEGO\Python\data\3003.pov
D:\LEGO\Python\data\3002.ldr -ExportFile=D:\LEGO\Python\data\3004.pov
D:\LEGO\Python\data\3002.ldr -ExportFile=D:\LEGO\Python\data\3005.pov
D:\LEGO\Python\data\3002.ldr -ExportFile=D:\LEGO\Python\data\3006.pov
D:\LEGO\Python\data\3002.ldr -ExportFile=D:\LEGO\Python\data\3007.pov
D:\LEGO\Python\data\3002.ldr -ExportFile=D:\LEGO\Python\data\3008.pov
D:\Installations\LDRAW\LDView64\LDView64.exe -CommandLinesList=D:\LEGO\Python\data\commandlist.txt
