(2021-02-10, 18:34)Leonardo Gonzalez Wrote: [ -> ]I tested LDView using the Radeon Software version: 20.12.1 and it works as expected. Then without making any other changes, updated the Radeon Software and upon restarting after completing the installation LDView no longer works.
I can confirm, without a doubt, that the Radeon Software version: 21.2.1 breaks LDView 4.3 (in both 32-bit and 64-bit).
Thank you for tracking that down.
This is very unfortunate. LDView uses truly ancient OpenGL functionality, that probably doesn't get used by any modern 3D apps. As such, AMD might not even know that they introduced a bug. And I have no way to reproduce the issue, since I don't have any Radeon graphics cards available to me.
I have a Ryzen with integrated VEGA graphics system I can use to test.
After further looking into it, I have found this:
- Radeon Software version: 21.2.1 is an "optional" update and not a "recommended" one. This means that it does not contain critical updates (or must have) from AMD, rather some minor specific changes. If these changes do not affect the use of your video card you can skip the optional update (if you haven't installed it yet) until the next recommended update is available. Hopefully with better results.
- You can immediately gain back the use of LDView by uninstalling the Radeon Software (in this specific case, meaning if you updated to 21.2.1).
- If you would like to have access to the video card functionality with the previous version of the software (without the optional update stuff) you can download it on the official AMD website by clicking this link and scrolling down to the installation package:
Radeon Software version 20.12.1
- In the very rare event that the uninstall fails, AMD provides a cleanup tool that you can run to remove traces of the Radeon Software. Follow this link for the
AMD Cleanup Utility.
I will keep track of this for the next update and maybe submit a bug report to AMD with their own report tool.
An update on the software situation with the LDView 4.3
Radeon Software version: 21.3.1 (considered a Recommended update released: 3/10/2021) continues to breaks LDView 4.3.
Radeon Software version: 21.4.1 (considered a Recommended update released: 4/13/2021) continues to breaks LDView 4.3. Also failed with LDView 4.4 Beta 4 test release.
(2021-05-17, 23:26)Leonardo Gonzalez Wrote: [ -> ]Radeon Software version: 21.4.1 (considered a Recommended update released: 4/13/2021) continues to breaks LDView 4.3. Also failed with LDView 4.4 Beta 4 test release.
Unfortunately, unless you (or someone else with a Radeon card that's not working) is willing to build LDView from source and run it in a debugger, this is not likely to ever be fixed. You could try reporting it to AMD.
As an aside, you might try running with -IgnoreAllOGLExtensions=1 on the command line. If this fixes the problem, you can then try disabling each of the supported extensions one by one. The individual Ignore settings are:
- IgnoreAniso
- IgnoreFramebufferObject
- IgnoreMultiDrawArrays
- IgnoreMultisample
- IgnoreMultisampleFilterHint
- IgnorePBuffer
- IgnorePixelFormat
- IgnoreVAR
- IgnoreVBO
I did submit a report to AMD, I doubt that will result in any help from them.
I was forced to remove the Radeon Software version: 21.4.1 because it was causing constant intermittent crashes on my card (I counted 11 in about 30 seconds). Nonetheless, I will definitely try your suggestions. I'm not sure about the compiling part, but I can certainly test the program with the extensions off. Will report back on my findings.
I was able to do some testing before my computer crashed (due to the drivers). I went through the whole list, but only one command works to get the program working.
The -IgnoreMultisample=1 command line allows LDView to work in the newer Radeon drivers.
(2021-05-24, 18:48)Leonardo Gonzalez Wrote: [ -> ]I was able to do some testing before my computer crashed (due to the drivers). I went through the whole list, but only one command works to get the program working.
That's certainly good news. Out of curiosity, did you have FSAA enabled in LDView? If so, could you try disabling it, and then see if it will run without that setting? I can look at the code that gets enabled by that setting, but I'm still doubtful that I'll be able to fix it.
(2021-05-24, 23:28)Travis Cobbs Wrote: [ -> ]That's certainly good news. Out of curiosity, did you have FSAA enabled in LDView? If so, could you try disabling it, and then see if it will run without that setting? I can look at the code that gets enabled by that setting, but I'm still doubtful that I'll be able to fix it.
Apologies for the extremely long delay.
Yes, if I set the FSAA to off, then update the drivers, and open LDView, the program is able to run.
