Hey LDraw community,
I am having an issue with importing my .ldr file into Unity.
I am using the Lego model importer that comes with the Lego Mini Game on the Unity game engine website.
When I import my model, parts of it are rotated on in the wrong position.
I checked the ldraw xml file and I have the most recent version.
Does anyone have an idea how to fix this?
![[Image: EqV3t3mXEAEKI_f?format=jpg&name=large]](https://pbs.twimg.com/media/EqV3t3mXEAEKI_f?format=jpg&name=large)
Hi (and welcome here!)
Quote:I checked the ldraw xml file and I have the most recent version.
Are you sure? The version that I installed here with Unity is dated 2020-02-02 and doesn't contain mapping for parts 65634, 65635 and 66727. Latest one is stamped 2020-12-23.
Unity LDraw.xml is located in C:\Users\{your user name}\MyFirstGame\Library\PackageCache\
[email protected]\Data
Keep a backup the original one if the new one doesn't work (it seems to be fine here)
Thank you for the reply!
Quote:Are you sure? The version that I installed here with Unity is dated 2020-02-02 and doesn't contain mapping for parts 65634, 65635 and 66727. Latest one is stamped 2020-12-23.
You are correct I hadn't updated the xml file like I thought and now get no import errors.
However, the positioning of parts is still not correct.
Do you know how to fix this?
(2020-12-29, 19:15)ajs Wrote: [ -> ]Do you know how to fix this?
Can you share your LDraw model?
(2020-12-29, 21:24)ajs Wrote: [ -> ]Sure!
Here you go.
OK, sorry, I give up with this one: looks like ldraw.xml gets overwritten when Microgame is launched
No worries, thank you so much for having a look for me and helping me out.
I will use other bricks instead.
Have same problem. as i understod the developer have removed the project and discontinued it
is there a way to for example make the tool use the latest Ldraw parts instead of the old one that it uses. if its possible pls contact me as soon as possible.
