Hi Bernhard,
First welcome here!
Not a simple problem...
and what doesn't help either is that the demo viewer https://ldr.netlify.app/ doesn't seem to work fine. Apart from preloaded X-wing, all files I tried (including the MPDs from github folder) stay stuck loading at 0%! Forget that, I goofed when retrieving files, it works . Still searching a method!
(2020-12-20, 16:56)Philippe Hurbain Wrote: [ -> ]Hi Bernhard,
First welcome here!
Not a simple problem... and what doesn't help either is that the demo viewer https://ldr.netlify.app/ doesn't seem to work fine. Apart from preloaded X-wing, all files I tried (including the MPDs from github folder) stay stuck loading at 0%! Forget that, I goofed when retrieving files, it works . Still searching a method!
Hi Philippe,
I wrote now following python script (main.py).
import re
import sys
import os.path
from pathlib import Path
import requests
class DatFile:
def __init__(self, name):
self.name = name
self.cacheDirectory = 'files'
Path(self.cacheDirectory).mkdir(parents=True, exist_ok=True)
def getDependencies(self):
dependencies = {}
content = self.getContent()
matches = re.finditer(r"([^ ]*\.dat$)", content, re.MULTILINE)
for matchNum, match in enumerate(matches, start=1):
for groupNum in range(0, len(match.groups())):
dependency = match.group(groupNum)
if dependency not in dependencies:
dependencies[dependency] = DatFile(dependency)
return dependencies
def getName(self):
return self.name
def getContent(self):
if not self.isCached():
self.writeToDisc(self.downloadFile())
return self.readFromDisc()
def getContentAsRoot(self):
return content.replace("0 !LDRAW_ORG Part", "0 !LDRAW_ORG Configuration")
def isCached(self):
return os.path.isfile(self.getCacheFileName())
def getCacheFileName(self):
return f"{self.cacheDirectory}/{self.name}"
def readFromDisc(self):
with open(self.getCacheFileName(), 'r') as file:
content = file.read()
return content
def writeToDisc(self, content):
with open(self.getCacheFileName(), 'w', encoding='utf-8', newline='') as file:
file.write(content)
file.flush()
def downloadFile(self):
urls= [ f"https://www.ldraw.org/library/official/p/{self.name}", f"https://www.ldraw.org/library/official/parts/{self.name}" ]
for url in urls:
req = requests.get(url)
if req.status_code == 200:
return req.text
raise Exception(f"File not Found: {self.name}")
def startParsing(name, headefile):
rootFile = DatFile(name)
print(rootFile.getContentAsRoot())
print(readHeaderFile(headefile))
print("0")
print("")
visitDependencies({}, DatFile(name))
def readHeaderFile(headerfile):
with open(headerfile, 'r') as file:
return content
def visitDependencies(visitedFiles, datFile):
filename = datFile.getName()
dependencies = datFile.getDependencies()
visitedFiles[filename] = True
for dependencyFilename in dependencies:
if not dependencyFilename in visitedFiles:
dependencyFile = dependencies[dependencyFilename]
print(f"0 FILE {dependencyFilename}")
print(dependencyFile.getContent())
print("0")
print("")
visitDependencies(visitedFiles, dependencyFile)
# Press the green button in the gutter to run the script.
if __name__ == '__main__':
filename = sys.argv[1]
headerfile = sys.argv[2]
startParsing(filename, headerfile)
Under Windows, I use it (createMPD.bat):
@echo off
set PYTHON_HOME=D:\media\infrastruktur\apps\python
set FILE=%1
%PYTHON_HOME%\python main.py %FILE% header.mpd > %FILE%.mpd
The header.mpd contains the COLOUR definitions, like (header.mpd):
0 // LDraw Solid Colours
0 // LEGOID 26 - Black
0 !COLOUR Black CODE 0 VALUE #05131D EDGE #595959
0 // LEGOID 23 - Bright Blue
0 !COLOUR Blue CODE 1 VALUE #0055BF EDGE #333333
0 // LEGOID 28 - Dark Green
0 !COLOUR Green CODE 2 VALUE #257A3E EDGE #333333
0 // LEGOID 107 - Bright Bluish Green
0 !COLOUR Dark_Turquoise CODE 3 VALUE #00838F EDGE #333333
0 // LEGOID 21 - Bright Red
0 !COLOUR Red CODE 4 VALUE #C91A09 EDGE #333333
0 // LEGOID 221 - Bright Purple
0 !COLOUR Dark_Pink CODE 5 VALUE #C870A0 EDGE #333333
0 // LEGOID 217 - Brown
0 !COLOUR Brown CODE 6 VALUE #583927 EDGE #1E1E1E
0 // LEGOID 2 - Grey
0 !COLOUR Light_Grey CODE 7 VALUE #9BA19D EDGE #333333
0 // LEGOID 27 - Dark Grey
0 !COLOUR Dark_Grey CODE 8 VALUE #6D6E5C EDGE #333333
0 // LEGOID 45 - Light Blue
0 !COLOUR Light_Blue CODE 9 VALUE #B4D2E3 EDGE #333333
0 // LEGOID 37 - Bright Green
0 !COLOUR Bright_Green CODE 10 VALUE #4B9F4A EDGE #333333
0 // LEGOID 116 - Medium Bluish Green
0 !COLOUR Light_Turquoise CODE 11 VALUE #55A5AF EDGE #333333
0 // LEGOID 4 - Brick Red
0 !COLOUR Salmon CODE 12 VALUE #F2705E EDGE #333333
0 // LEGOID 9 - Light Reddish Violet
0 !COLOUR Pink CODE 13 VALUE #FC97AC EDGE #333333
0 // LEGOID 24 - Bright Yellow
0 !COLOUR Yellow CODE 14 VALUE #F2CD37 EDGE #333333
0 // LEGOID 1 - White
0 !COLOUR White CODE 15 VALUE #FFFFFF EDGE #333333
0 // LEGOID 6 - Light Green
0 !COLOUR Light_Green CODE 17 VALUE #C2DAB8 EDGE #333333
0 // LEGOID 3 - Light Yellow
0 !COLOUR Light_Yellow CODE 18 VALUE #FBE696 EDGE #333333
0 // LEGOID 5 - Brick Yellow
0 !COLOUR Tan CODE 19 VALUE #E4CD9E EDGE #333333
0 // LEGOID 39 - Light Bluish Violet
0 !COLOUR Light_Violet CODE 20 VALUE #C9CAE2 EDGE #333333
0 // LEGOID 104 - Bright Violet
0 !COLOUR Purple CODE 22 VALUE #81007B EDGE #333333
0 // LEGOID 196 - Dark Royal Blue
0 !COLOUR Dark_Blue_Violet CODE 23 VALUE #2032B0 EDGE #1E1E1E
0 // LEGOID 106 - Bright Orange
0 !COLOUR Orange CODE 25 VALUE #FE8A18 EDGE #333333
0 // LEGOID 124 - Bright Reddish Violet
0 !COLOUR Magenta CODE 26 VALUE #923978 EDGE #333333
0 // LEGOID 119 - Bright Yellowish Green
0 !COLOUR Lime CODE 27 VALUE #BBE90B EDGE #333333
0 // LEGOID 138 - Sand Yellow
0 !COLOUR Dark_Tan CODE 28 VALUE #958A73 EDGE #333333
0 // LEGOID 222 - Light Purple
0 !COLOUR Bright_Pink CODE 29 VALUE #E4ADC8 EDGE #333333
0 // LEGOID 324 - Medium Lavender
0 !COLOUR Medium_Lavender CODE 30 VALUE #AC78BA EDGE #333333
0 // LEGOID 325 - Lavender
0 !COLOUR Lavender CODE 31 VALUE #E1D5ED EDGE #333333
0 // LEGOID 36 - Light Yellowish Orange
0 !COLOUR Very_Light_Orange CODE 68 VALUE #F3CF9B EDGE #333333
0 // LEGOID 198 - Bright Reddish Lilac
0 !COLOUR Bright_Reddish_Lilac CODE 69 VALUE #CD6298 EDGE #333333
0 // LEGOID 192 - Reddish Brown
0 !COLOUR Reddish_Brown CODE 70 VALUE #582A12 EDGE #595959
0 // LEGOID 194 - Medium Stone Grey
0 !COLOUR Light_Bluish_Grey CODE 71 VALUE #A0A5A9 EDGE #333333
0 // LEGOID 199 - Dark Stone Grey
0 !COLOUR Dark_Bluish_Grey CODE 72 VALUE #6C6E68 EDGE #333333
0 // LEGOID 102 - Medium Blue
0 !COLOUR Medium_Blue CODE 73 VALUE #5C9DD1 EDGE #333333
0 // LEGOID 29 - Medium Green
0 !COLOUR Medium_Green CODE 74 VALUE #73DCA1 EDGE #333333
0 // LEGOID 223 - Light Pink
0 !COLOUR Light_Pink CODE 77 VALUE #FECCCF EDGE #333333
0 // LEGOID 283 - Light Nougat
0 !COLOUR Light_Flesh CODE 78 VALUE #F6D7B3 EDGE #333333
0 // LEGOID 38 - Dark Orange
0 !COLOUR Medium_Dark_Flesh CODE 84 VALUE #CC702A EDGE #333333
0 // LEGOID 268 - Medium Lilac
0 !COLOUR Medium_Lilac CODE 85 VALUE #3F3691 EDGE #1E1E1E
0 // LEGOID 312 - Medium Nougat
0 !COLOUR Dark_Flesh CODE 86 VALUE #7C503A EDGE #333333
0 // LEGOID 195 - Medium Royal Blue
0 !COLOUR Blue_Violet CODE 89 VALUE #4C61DB EDGE #333333
0 // LEGOID 18 - Nougat
0 !COLOUR Flesh CODE 92 VALUE #D09168 EDGE #333333
0 // LEGOID 100 - Light Red
0 !COLOUR Light_Salmon CODE 100 VALUE #FEBABD EDGE #333333
0 // LEGOID 110 - Bright Bluish Violet
0 !COLOUR Violet CODE 110 VALUE #4354A3 EDGE #333333
0 // LEGOID 112 - Medium Bluish Violet
0 !COLOUR Medium_Violet CODE 112 VALUE #6874CA EDGE #333333
0 // LEGOID 115 - Medium Yellowish Green
0 !COLOUR Medium_Lime CODE 115 VALUE #C7D23C EDGE #333333
0 // LEGOID 118 - Light Bluish Green
0 !COLOUR Aqua CODE 118 VALUE #B3D7D1 EDGE #333333
0 // LEGOID 120 - Light Yellowish Green
0 !COLOUR Light_Lime CODE 120 VALUE #D9E4A7 EDGE #333333
0 // LEGOID 125 - Light Orange
0 !COLOUR Light_Orange CODE 125 VALUE #F9BA61 EDGE #333333
0 // LEGOID 208 - Light Stone Grey
0 !COLOUR Very_Light_Bluish_Grey CODE 151 VALUE #E6E3E0 EDGE #333333
0 // LEGOID 191 - Flame Yellowish Orange
0 !COLOUR Bright_Light_Orange CODE 191 VALUE #F8BB3D EDGE #333333
0 // LEGOID 212 - Light Royal Blue
0 !COLOUR Bright_Light_Blue CODE 212 VALUE #86C1E1 EDGE #333333
0 // LEGOID 216 - Rust
0 !COLOUR Rust CODE 216 VALUE #B31004 EDGE #333333
0 // LEGOID 226 - Cool Yellow
0 !COLOUR Bright_Light_Yellow CODE 226 VALUE #FFF03A EDGE #333333
0 // LEGOID 232 - Dove Blue
0 !COLOUR Sky_Blue CODE 232 VALUE #56BED6 EDGE #333333
0 // LEGOID 140 - Earth Blue
0 !COLOUR Dark_Blue CODE 272 VALUE #0D325B EDGE #1E1E1E
0 // LEGOID 141 - Earth Green
0 !COLOUR Dark_Green CODE 288 VALUE #184632 EDGE #595959
0 // LEGOID 308 - Dark Brown
0 !COLOUR Dark_Brown CODE 308 VALUE #352100 EDGE #595959
0 // LEGOID 11 - Pastel Blue
0 !COLOUR Maersk_Blue CODE 313 VALUE #54A9C8 EDGE #333333
0 // LEGOID 154 - New Dark Red
0 !COLOUR Dark_Red CODE 320 VALUE #720E0F EDGE #333333
0 // LEGOID 321 - Dark Azur
0 !COLOUR Dark_Azure CODE 321 VALUE #1498D7 EDGE #333333
0 // LEGOID 322 - Medium Azur
0 !COLOUR Medium_Azure CODE 322 VALUE #3EC2DD EDGE #333333
0 // LEGOID 323 - Aqua
0 !COLOUR Light_Aqua CODE 323 VALUE #BDDCD8 EDGE #333333
0 // LEGOID 326 - Spring Yellowish Green
0 !COLOUR Yellowish_Green CODE 326 VALUE #DFEEA5 EDGE #333333
0 // LEGOID 330 - Olive Green
0 !COLOUR Olive_Green CODE 330 VALUE #9B9A5A EDGE #333333
0 // LEGOID 153 - Sand Red
0 !COLOUR Sand_Red CODE 335 VALUE #D67572 EDGE #333333
0 // LEGOID 22 - Medium Reddish Violet
0 !COLOUR Medium_Dark_Pink CODE 351 VALUE #F785B1 EDGE #333333
0 // LEGOID 25 - Earth Orange
0 !COLOUR Earth_Orange CODE 366 VALUE #FA9C1C EDGE #333333
0 // LEGOID 136 - Sand Violet
0 !COLOUR Sand_Purple CODE 373 VALUE #845E84 EDGE #333333
0 // LEGOID 151 - Sand Green
0 !COLOUR Sand_Green CODE 378 VALUE #A0BCAC EDGE #333333
0 // LEGOID 135 - Sand Blue
0 !COLOUR Sand_Blue CODE 379 VALUE #597184 EDGE #333333
0 // LEGOID 12 - Light Orange Brown
0 !COLOUR Fabuland_Brown CODE 450 VALUE #B67B50 EDGE #333333
0 // LEGOID 105 - Bright Yellowish Orange
0 !COLOUR Medium_Orange CODE 462 VALUE #FFA70B EDGE #333333
0 !COLOUR Dark_Orange CODE 484 VALUE #A95500 EDGE #333333
0 // LEGOID 103 - Light Grey
0 !COLOUR Very_Light_Grey CODE 503 VALUE #E6E3DA EDGE #333333
0 // LEGOID 218 - Reddish Lilac
0 !COLOUR Reddish_Lilac CODE 218 VALUE #8E5597 EDGE #333333
0 // LEGOID 295 - Flamingo Pink
0 !COLOUR Flamingo_Pink CODE 295 VALUE #FF94C2 EDGE #333333
0 // LEGOID 219 - Lilac
0 !COLOUR Lilac CODE 219 VALUE #564E9D EDGE #333333
0 // LEGOID 128 - Dark Nougat
0 !COLOUR Dark_Nougat CODE 128 VALUE #AD6140 EDGE #333333
0 // LDraw Transparent Colours
0 // LEGOID 40 - Transparent
0 !COLOUR Trans_Clear CODE 47 VALUE #FCFCFC EDGE #C3C3C3 ALPHA 128
0 // LEGOID 111 - Transparent Brown
0 !COLOUR Trans_Black CODE 40 VALUE #635F52 EDGE #171316 ALPHA 128
0 // LEGOID 41 - Transparent Red
0 !COLOUR Trans_Red CODE 36 VALUE #C91A09 EDGE #880000 ALPHA 128
0 // LEGOID 47 - Transparent Fluorescent Reddish Orange
0 !COLOUR Trans_Neon_Orange CODE 38 VALUE #FF800D EDGE #BD2400 ALPHA 128
0 // LEGOID 182 - Trans Bright Orange
0 !COLOUR Trans_Orange CODE 57 VALUE #F08F1C EDGE #A45C28 ALPHA 128
0 // LEGOID 157 - Transparent Fluorescent Yellow
0 !COLOUR Trans_Neon_Yellow CODE 54 VALUE #DAB000 EDGE #C3BA3F ALPHA 128
0 // LEGOID 44 - Transparent Yellow
0 !COLOUR Trans_Yellow CODE 46 VALUE #F5CD2F EDGE #8E7400 ALPHA 128
0 // LEGOID 49 - Transparent Fluorescent Green
0 !COLOUR Trans_Neon_Green CODE 42 VALUE #C0FF00 EDGE #84C300 ALPHA 128
0 // LEGOID 311 / 227 - Transparent Bright Green / Transparent Bright Yellowish Green
0 !COLOUR Trans_Bright_Green CODE 35 VALUE #56E646 EDGE #9DA86B ALPHA 128
0 // LEGOID 48 - Transparent Green
0 !COLOUR Trans_Green CODE 34 VALUE #237841 EDGE #1E6239 ALPHA 128
0 // LEGOID 43 - Transparent Blue
0 !COLOUR Trans_Dark_Blue CODE 33 VALUE #0020A0 EDGE #000064 ALPHA 128
0 // LEGOID 143 - Transparent Fluorescent Blue
0 !COLOUR Trans_Medium_Blue CODE 41 VALUE #559AB7 EDGE #196973 ALPHA 128
0 // LEGOID 42 - Transparent Light Blue
0 !COLOUR Trans_Light_Blue CODE 43 VALUE #AEE9EF EDGE #72B3B0 ALPHA 128
0 // LEGOID 229 - Transparent Light Bluish Green
0 !COLOUR Trans_Very_Light_Blue CODE 39 VALUE #C1DFF0 EDGE #85A3B4 ALPHA 128
0 // LEGOID 236 - Transparent Bright Reddish Lilac
0 !COLOUR Trans_Bright_Reddish_Lilac CODE 44 VALUE #96709F EDGE #5A3463 ALPHA 128
0 // LEGOID 126 - Transparent Bright Bluish Violet
0 !COLOUR Trans_Purple CODE 52 VALUE #A5A5CB EDGE #280025 ALPHA 128
0 // LEGOID 113 - Transparent Medium Reddish Violet
0 !COLOUR Trans_Dark_Pink CODE 37 VALUE #DF6695 EDGE #A32A59 ALPHA 128
0 // LEGOID 230 - Transparent Bright Pink
0 !COLOUR Trans_Pink CODE 45 VALUE #FC97AC EDGE #A8718C ALPHA 128
0 // LEGOID 285 - Transparent Light Green
0 !COLOUR Trans_Light_Green CODE 285 VALUE #7DC291 EDGE #52805F ALPHA 128
0 // LEGOID 234 - Transparent Fire Yellow
0 !COLOUR Trans_Fire_Yellow CODE 234 VALUE #FBE890 EDGE #BAAB6A ALPHA 128
0 // LEGOID 293 - Transparent Light Royal Blue
0 !COLOUR Trans_Light_Blue_Violet CODE 293 VALUE #6BABE4 EDGE #4D7BA3 ALPHA 128
0 // LEGOID 231 - Transparent Flame Yellowish Orange
0 !COLOUR Trans_Bright_Light_Orange CODE 231 VALUE #FCB76D EDGE #BD8951 ALPHA 128
0 // LEGOID 284 - Transparent Reddish Lilac
0 !COLOUR Trans_Reddish_Lilac CODE 284 VALUE #C281A5 EDGE #82566E ALPHA 128
0 // LDraw Chrome Colours
0 // LEGOID 299 - Warm Gold Drum Lacq
0 !COLOUR Chrome_Gold CODE 334 VALUE #BBA53D EDGE #BBB23D CHROME
0 // LEGOID 298 - Cool Silver Drum Lacq
0 !COLOUR Chrome_Silver CODE 383 VALUE #E0E0E0 EDGE #A4A4A4 CHROME
0 // LEGOID 187 - Metallic Earth Orange
0 !COLOUR Chrome_Antique_Brass CODE 60 VALUE #645A4C EDGE #281E10 CHROME
0 !COLOUR Chrome_Black CODE 64 VALUE #1B2A34 EDGE #595959 CHROME
0 // LEGOID 185 - Metallic Bright Blue
0 !COLOUR Chrome_Blue CODE 61 VALUE #6C96BF EDGE #202A68 CHROME
0 // LEGOID 147 - Metallic Dark Green
0 !COLOUR Chrome_Green CODE 62 VALUE #3CB371 EDGE #007735 CHROME
0 !COLOUR Chrome_Pink CODE 63 VALUE #AA4D8E EDGE #6E1152 CHROME
0 // LDraw Pearl Colours
0 // LEGOID 183 - Metallic White
0 !COLOUR Pearl_White CODE 183 VALUE #F2F3F2 EDGE #333333 PEARLESCENT
0 // LEGOID 150 - Metallic Light Grey
0 !COLOUR Pearl_Very_Light_Grey CODE 150 VALUE #BBBDBC EDGE #333333 PEARLESCENT
0 // LEGOID 179 / 296 / 131 / 315 - Silver Flip-flop / Cool Silver / Silver / Silver Metallic
0 !COLOUR Pearl_Light_Grey CODE 135 VALUE #9CA3A8 EDGE #333333 PEARLESCENT
0 // LEGOID 131 - Silver
0 !COLOUR Flat_Silver CODE 179 VALUE #898788 EDGE #333333 PEARLESCENT
0 // LEGOID 148 - Metallic Dark Grey
0 !COLOUR Pearl_Dark_Grey CODE 148 VALUE #575857 EDGE #333333 PEARLESCENT
0 // LEGOID 145 - Sand Blue Metallic
0 !COLOUR Metal_Blue CODE 137 VALUE #5677BA EDGE #333333 PEARLESCENT
0 // LEGOID 127 - Gold
0 !COLOUR Pearl_Light_Gold CODE 142 VALUE #DCBE61 EDGE #333333 PEARLESCENT
0 // LEGOID 297 - Warm Gold
0 !COLOUR Pearl_Gold CODE 297 VALUE #CC9C2B EDGE #333333 PEARLESCENT
0 // LEGOID 147 - Metallic Sand Yellow
0 !COLOUR Flat_Dark_Gold CODE 178 VALUE #B4883E EDGE #333333 PEARLESCENT
0 // LEGOID 139 - Copper
0 !COLOUR Copper CODE 134 VALUE #964A27 EDGE #333333 PEARLESCENT
0 // LEGOID 189 - Reddish Gold
0 !COLOUR Reddish_Gold CODE 189 VALUE #AC8247 EDGE #333333 PEARLESCENT
0 // LDraw Metallic Colours
0 // LEGOID 315 - Silver Metallic
0 !COLOUR Metallic_Silver CODE 80 VALUE #A5A9B4 EDGE #333333 METAL
0 // LEGOID 200 - Lemon Metallic
0 !COLOUR Metallic_Green CODE 81 VALUE #899B5F EDGE #333333 METAL
0 // LEGOID 310 / 335 Metalized Gold / Gold Ink
0 !COLOUR Metallic_Gold CODE 82 VALUE #DBAC34 EDGE #333333 METAL
0 // LEGOID 149 - Metallic Black
0 !COLOUR Metallic_Black CODE 83 VALUE #1A2831 EDGE #333333 METAL
0 // LEGOID 309 / 336 - Metalized Silver / Silver Ink
0 !COLOUR Metallic_Dark_Grey CODE 87 VALUE #6D6E5C EDGE #333333 METAL
0 // LEGOID 300 / 334 - Copper Drum Lacq / Copper Ink
0 !COLOUR Metallic_Copper CODE 300 VALUE #C27F53 EDGE #333333 METAL
0 // LEGOID 184 - Metallic Bright Red
0 !COLOUR Metallic_Bright_Red CODE 184 VALUE #D60026 EDGE #333333 METAL
0 // LEGOID 186 - Metallic Dark Green
0 !COLOUR Metallic_Dark_Green CODE 186 VALUE #008E3C EDGE #333333 METAL
0 // LDraw Milky Colours
0 // LEGOID 20 - Nature
0 !COLOUR Milky_White CODE 79 VALUE #FFFFFF EDGE #C3C3C3 ALPHA 240
0 // LEGOID 294 - Phosphorescent Green
0 !COLOUR Glow_In_Dark_Opaque CODE 21 VALUE #E0FFB0 EDGE #A4C374 ALPHA 240 LUMINANCE 15
0 // LEGOID 50 - Phosphorescent White
0 !COLOUR Glow_In_Dark_Trans CODE 294 VALUE #BDC6AD EDGE #818A71 ALPHA 240 LUMINANCE 15
0 // LEGOID 329 - White Glow
0 !COLOUR Glow_In_Dark_White CODE 329 VALUE #F5F3D7 EDGE #B5B49F ALPHA 240 LUMINANCE 15
0 // LDraw Glitter Colours
0 // LEGOID 114 - Tr. Medium Reddish-Violet w. Glitter 2%
0 !COLOUR Glitter_Trans_Dark_Pink CODE 114 VALUE #DF6695 EDGE #9A2A66 ALPHA 128 MATERIAL GLITTER VALUE #923978 FRACTION 0.17 VFRACTION 0.2 SIZE 1
0 // LEGOID 117 - Transparent Glitter
0 !COLOUR Glitter_Trans_Clear CODE 117 VALUE #FFFFFF EDGE #C3C3C3 ALPHA 128 MATERIAL GLITTER VALUE #FFFFFF FRACTION 0.08 VFRACTION 0.1 SIZE 1
0 // LEGOID 129 - Tr. Bright Bluish Violet w. Glitter 2%
0 !COLOUR Glitter_Trans_Purple CODE 129 VALUE #640061 EDGE #280025 ALPHA 128 MATERIAL GLITTER VALUE #8C00FF FRACTION 0.3 VFRACTION 0.4 SIZE 1
0 // LEGOID 302 Tr. Light Blue with Glitter 2%
0 !COLOUR Glitter_Trans_Light_Blue CODE 302 VALUE #AEE9EF EDGE #72B3B0 ALPHA 128 MATERIAL GLITTER VALUE #923978 FRACTION 0.17 VFRACTION 0.2 SIZE 1
0 // LEGOID 339 Tr Fluorescent Green with Glitter 2%
0 !COLOUR Glitter_Trans_Neon_Green CODE 339 VALUE #C0FF00 EDGE #84C300 ALPHA 128 MATERIAL GLITTER VALUE #923978 FRACTION 0.17 VFRACTION 0.2 SIZE 1
0 // LDraw Speckle Colours
0 !COLOUR Speckle_Black_Silver CODE 132 VALUE #000000 EDGE #898788 MATERIAL SPECKLE VALUE #898788 FRACTION 0.4 MINSIZE 1 MAXSIZE 3
0 // LEGOID 132 - Black Glitter
0 !COLOUR Speckle_Black_Gold CODE 133 VALUE #000000 EDGE #DBAC34 MATERIAL SPECKLE VALUE #DBAC34 FRACTION 0.4 MINSIZE 1 MAXSIZE 3
0 !COLOUR Speckle_Black_Copper CODE 75 VALUE #000000 EDGE #AB6038 MATERIAL SPECKLE VALUE #AB6038 FRACTION 0.4 MINSIZE 1 MAXSIZE 3
0 !COLOUR Speckle_Dark_Bluish_Grey_Silver CODE 76 VALUE #635F61 EDGE #898788 MATERIAL SPECKLE VALUE #898788 FRACTION 0.4 MINSIZE 1 MAXSIZE 3
0 // LDraw Rubber Colours
0 !COLOUR Rubber_Yellow CODE 65 VALUE #F5CD2F EDGE #333333 RUBBER
0 !COLOUR Rubber_Trans_Yellow CODE 66 VALUE #CAB000 EDGE #8E7400 ALPHA 128 RUBBER
0 !COLOUR Rubber_Trans_Clear CODE 67 VALUE #FFFFFF EDGE #C3C3C3 ALPHA 128 RUBBER
0 !COLOUR Rubber_Black CODE 256 VALUE #212121 EDGE #595959 RUBBER
0 !COLOUR Rubber_Blue CODE 273 VALUE #0033B2 EDGE #333333 RUBBER
0 !COLOUR Rubber_Red CODE 324 VALUE #C40026 EDGE #333333 RUBBER
0 !COLOUR Rubber_Orange CODE 350 VALUE #D06610 EDGE #333333 RUBBER
0 !COLOUR Rubber_Light_Grey CODE 375 VALUE #C1C2C1 EDGE #333333 RUBBER
0 !COLOUR Rubber_Dark_Blue CODE 406 VALUE #001D68 EDGE #595959 RUBBER
0 !COLOUR Rubber_Purple CODE 449 VALUE #81007B EDGE #333333 RUBBER
0 !COLOUR Rubber_Lime CODE 490 VALUE #D7F000 EDGE #333333 RUBBER
0 !COLOUR Rubber_Light_Bluish_Grey CODE 496 VALUE #A3A2A4 EDGE #333333 RUBBER
0 !COLOUR Rubber_Flat_Silver CODE 504 VALUE #898788 EDGE #333333 RUBBER
0 !COLOUR Rubber_White CODE 511 VALUE #FAFAFA EDGE #333333 RUBBER
0 // LDraw Internal Common Material Colours
0 !COLOUR Main_Colour CODE 16 VALUE #FFFF80 EDGE #333333
0 !COLOUR Edge_Colour CODE 24 VALUE #7F7F7F EDGE #333333
0 // LEGOID 109 - Black IR
0 !COLOUR Trans_Black_IR_Lens CODE 32 VALUE #000000 EDGE #333333 ALPHA 210
0 !COLOUR Magnet CODE 493 VALUE #656761 EDGE #595959 METAL
0 !COLOUR Electric_Contact_Alloy CODE 494 VALUE #D0D0D0 EDGE #333333 METAL
0 !COLOUR Electric_Contact_Copper CODE 495 VALUE #AE7A59 EDGE #333333 METAL
0
I tested the script with the 4186.dat and it works fine. The result can be viewed in
That was a funny sunday afternoon task :-)
Great you found a solution!
Now I need to install a Windows Python (I only use the Spike Prime and PyBricks versions...)
(2020-12-20, 17:22)Philippe Hurbain Wrote: [ -> ]Great you found a solution!
The script is very buggy right now. I did a few corrections.
But the viewer has problems with file references like "s\10s01.dat".
I had to replace the backslash with __ for example.
Now a few other files works. But most files don't.
Is there a mpd file verifier script so that I can check if the generated file is correct?
Cheers,
Bernhard
I think this could be achieved by using MPDCenter (contained inside the All-in-one-installer).
Simply configure in its options that the "official" files setting points to an empty folder,
and let the "unofficial parts" folder point to the LDRAW folder.
(2020-12-21, 2:33)Steffen Wrote: [ -> ]I think this could be achieved by using MPDCenter (contained inside the All-in-one-installer).
That's whet I tried first, but it doesn't seem to work...
(2020-12-20, 12:57)Bernhard Wrote: [ -> ]Hi guys,
I'm totally new and very fascinated by ldraw.
I'm a software engineer and would like to view custom created models using this software: https://github.com/EvanBacon/Lego-Expo
Here is an online demo of the viewer: https://ldr.netlify.app/
The tools read MPD files. Example files can be found here: https://github.com/EvanBacon/Lego-Expo/t...ary/models
My understanding is that the files have to contain the declaration of all parts used in the model. No external references are allowed.
As a test, I would like to use a simple baseplate and view it using Lego-Expo. I found this baseplate: https://www.ldraw.org/parts/official-par...artid=4186
Is there a way to generate an MPD file with all the referenced parts based on a DAT-file (like the parts/4186.dat) ?
I couldn't found such a tool.
Thanks for your help!
Cheers,
Bernhard
Hi Bernhard,
you should try my program
MPDCenter for your purpose.
cu
Mikeheide
(2020-12-20, 12:57)Bernhard Wrote: [ -> ]Is there a way to generate an MPD file with all the referenced parts based on a DAT-file (like the parts/4186.dat) ?
Hi Bernhard,
I'm late, but if you would like to give
LDInspector (very beta) a chance, you can point to your mpd-file ("File" from the top menu), then select "Edit" pane and therein "Inline Parts" - "All used". Back on the "Item" pane click "Save item as new file" to have a mpd-file without external reference (hopefully).
Best regards
Stefan
(2020-12-30, 22:48)Stefan Frenz Wrote: [ -> ]Hi Bernhard,
I'm late, but if you would like to give LDInspector (very beta) a chance, you can point to your mpd-file ("File" from the top menu), then select "Edit" pane and therein "Inline Parts" - "All used". Back on the "Item" pane click "Save item as new file" to have a mpd-file without external reference (hopefully).
Best regards
Stefan
Can prove useful! Thanks for the tip!!!
