I'll take this part.
Part number is 973pcd6 (Collectible minifigures (numbered series) - Series 13, No.6)
Please wait for a while to create the print pattern.
(2021-02-18, 8:38)Takeshi Takahashi Wrote: [ -> ]Done!!
https://www.ldraw.org/cgi-bin/ptdetail.c...73pcd6.dat
If you (or other member) find any errors, I'll correct them.
Hello,
I mean the colors are not quite right. I changed the colours in my copy and attached it below. The numbers in the picture are the LDraw colors which I think are correct.
attachment=6128]
Greeting
Manfred
I think what you have labeled as 226 should be 14. The slight darkening of the yellow is due to the dark tan base plastic and yellow is the color of minifig "flesh"
(2021-03-04, 22:13)Orion Pobursky Wrote: [ -> ]I think what you have labeled as 226 should be 14. The slight darkening of the yellow is due to the dark tan base plastic and yellow is the color of minifig "flesh"
I think that the colors chosen by Takeshi are right (including the dark grey of shirt shadows). Bleed through of plastic dark tan color can be misleading! It's more questionable for buckle color, but I think that plain yellow is right: if you look at this video
https://youtu.be/CGvi6zpKRD4?t=248 you see no light reflection that metallic ink would show at some angles.
(2021-03-05, 9:03)Philippe Hurbain Wrote: [ -> ]I think that the colors chosen by Takeshi are right (including the dark grey of shirt shadows). Bleed through of plastic dark tan color can be misleading! It's more questionable for buckle color, but I think that plain yellow is right: if you look at this video https://youtu.be/CGvi6zpKRD4?t=248 you see no light reflection that metallic ink would show at some angles.
IMHO the belt buckle is Metallic Gold. The video shows there is a change of the yellow ink with a slight light reflection according to some angles
I have this figure.
The colours are Black, DBGrey, Tan, Yellow and Metallic gold.
(2021-03-05, 15:43)Magnus Forsberg Wrote: [ -> ]I have this figure.
Hello,
I also have this minifig body.
To check the colours, I have used tiles.
Okay, there some points, which can have influence. The light of the environment, the colour on the screen.
If this part will be an official part with this colours, it is no problem for me.
I am happy that this part ist realized and many thank to the part author.
Greeting
Manfred
