Full Version: 0.8.52 Beta Released (bugfix for newer Java versions)
Hey,
this release added support for newer Java versions (e.g. Java 9, Java 10...).
The minimum required Java version is still version 8. You can skip this release if you like, since no other features were added.
[Image: imgDuke2.png]
Changelog:
(1 bug fix)
With this release the following critical issue is fixed:
  1. The Windows program (LDPartEditor.exe) will now start with support of newer Java versions.
  1. Download the zip-Archive
  3. On windows, double-click "run.bat" to start LDPE.
  4. On linux/mac, you have to excecute the shell script "run.sh" to start LDPE.
Please note that this software is in the beta stage. Although, this version was tested, there are already known issues  for this release. There is a potential risk of data loss.
  2. On linux/mac, you have to excecute the shell script "update.sh".
System Requirements:
Minimum System Requirements:
  • 64-bit Java Runtime Environment (JRE) 1.8
  • Operating System (64-bit): Windows [7 or newer], Linux [e.g. Ubuntu Linux >=14.4], Mac OS X [>=10.6]
  • RAM: 4GB
  • Video-Memory: 1 GB
  • Free Disk Space: 100 MB
Recommended Requirements:
  • 64-bit Java Runtime Environment (JRE) 1.8 (or newer)
  • Operating System (64bit): Windows 7,8,10, Linux [e.g. Ubuntu Linux >=14.4], Mac OS X [>=10.6]
  • OpenGL 3.3 compatible Graphics Card
  • RAM: >4 GB
  • Video-Memory: >1 GB
  • Free Disk Space: 512 MB
  • For a faster start, LDPartEditor and the LDraw™ library should be installed on an SSD.
java -d64 version
Probably not related to this version (and not so annoying since it shouldn't happen!), but if last line of a file is "0 BFC INVERTNEXT", 3D view freezes (and even if you open an other file, there is no refresh of 3D view). You have to close/reopen to get ldpe working again.
(2021-01-26, 16:41)Philippe Hurbain Wrote: [ -> ]Probably not related to this version (and not so annoying since it shouldn't happen!), but if last line of a file is "0 BFC INVERTNEXT", 3D view freezes (and even if you open an other file, there is no refresh of 3D view). You have to close/reopen to get ldpe working again.
Confirmed, but I'm also still running a 0.8.50 version on my machine.
I sometimes see the little vertex editor window stick to my screen. It stays on top a few seconds if I switch to my web browser.
It most often goes away, but sometimes it doesn't.
I just became aware of the "Make subpart from 3D selection" button (very useful!) but found a little bug: in the created subpart, all "0 BFC INVERTNEXT" metas get duplicated.
(2021-02-10, 13:50)Philippe Hurbain Wrote: [ -> ]I just became aware of the "Make subpart from 3D selection" button (very useful!) but found a little bug: in the created subpart, all "0 BFC INVERTNEXT" metas get duplicated.
Thanks. I was able to reproduce the bug and created an issue (#756).
(2021-02-12, 10:27)Nils Schmidt Wrote: [ -> ]Thanks. I was able to reproduce the bug and created an issue (#756).
Probably related: when creating subpart from 3D selection, comments of source file gets copied to subpart though they are obviously not part of the 3D selection.
(2021-02-15, 12:30)Philippe Hurbain Wrote: [ -> ].... comments of source file gets copied to subpart ....
But I want them to be copied. I want to select a section in the text editor, and then hit "Create a Subpart".
As it is now, I have to first select in the text editor, then hit "Show selection in 3D view", and then press "Create a Subpart",
(2021-02-15, 16:20)Magnus Forsberg Wrote: [ -> ]But I want them to be copied. I want to select a section in the text editor, and then hit "Create a Subpart".
This is indeed another (useful too) functionnality. But for current one with 3D view, including comments is mostly meaningless.
Thanks Philo. I was able to reproduce the issue (#769). The fix is included in the next release.
It is not so easy to reproduce since it depends on the current render mode (OpenGL 2.0 only).
The following modes will currently cause a freeze from an invalid INVERTNEXT without a type 1 line:
  • Red Backfaces
  • Real Backface Culling
  • Special Cond. Line Mode
It is not necessary that "0 BFC INVERTNEXT" is the last line in the file to trigger the error.
The next version "0.8.53 Beta" will use a different configuration file.
Therefore, it will be necessary to reset all your custom LDPE settings.
What you can do as a workaround:
  • run two LDPE instances in parallel (0.8.53 + 0.8.52) and open both option menus to sync the settings manually.
  • take screenshots from your option menu entries in 0.8.52 before installing 0.8.53.
Version 0.8.53 is not ready yet. It will include some bug-fixes and a lot of major/minor code optimizations.
In total, the release fixes about 100 different code issues.
I also started automated testing to further improve the software quality.
(2021-05-22, 17:27)Nils Schmidt Wrote: [ -> ]In total, the release fixes about 100 different code issues.
Heart Heart Heart
