2020-09-01, 17:25
Hey,
this release added support for newer Java versions (e.g. Java 9, Java 10...).
The minimum required Java version is still version 8. You can skip this release if you like, since no other features were added.
Changelog:
(1 bug fix)
With this release the following critical issue is fixed:
System Requirements:
Minimum System Requirements:
Changelog:
(1 bug fix)
- The Windows program (LDPartEditor.exe) will now start with support of newer Java versions.
- Download the zip-Archive
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- 64-bit Java Runtime Environment (JRE) 1.8 (or newer)
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
