2020-08-14, 17:54
Site search has been implemented for the main menu search bar. This turned out to be surprisingly easy. I'll reintegrate PT search shortly.
(2020-08-14, 17:54)re is no exact match.Orion Pobursky Wrote: [ -> ]Site search has been implemented for the main menu search bar. This turned out to be surprisingly easy. I'll reintegrate PT search shortly.
(2020-08-15, 10:16)Chris Dee Wrote: [ -> ]Did you change the default script on the PT menu?
(2020-08-15, 12:11)Magnus Forsberg Wrote: [ -> ]It seems like the PT is back in the state where it makes a search in the whole file.
A search on four digits gives a too long list of files, that contain the four digits somewhere in a vertex.
Please change it back.
(2020-08-16, 20:31)Chris Dee Wrote: [ -> ]Orion ???
(2020-08-17, 2:14)Orion Pobursky Wrote: [ -> ]I feel we need to have the search be as accessible and intuitive as possible. If someone searches for something using the provided search box, it should by default return relevant result for almost any keyword. With "part number and description" as the default, if you, for example, search for a Bricklink number you'll get nothing even though that part may exist in the library. This is why I changed the default to "header". I felt this would solve the problem nicely since all of the relevant information for a part is there.
As to the search box pointing to ptdetail instead of ptscan, I'll revert that.
