It is known in ldraw as 98138pz0
Find it here
I see, however, that it could use Brickheadz as a keyword, since you are not the only one who has trouble finding the part. As an example, the user "cuminflea" has uploaded it as 98138pb072
on brickhub.
(2020-08-13, 9:10)Lasse Deleuran Wrote: [ -> ]It is known in ldraw as 98138pz0 Find it here
I see, however, that it could use Brickheadz as a keyword, since you are not the only one who has trouble finding the part. As an example, the user "cuminflea" has uploaded it as 98138pb072 on brickhub.
It does have BrickHeadz as a keyword
Also, Rebrickable's part number was wrong so I submitted a change request.
(2020-08-13, 12:44)Orion Pobursky Wrote: [ -> ]It does have BrickHeadz as a keyword
It does indeed. So the issue is that the search does not consider keywords. Maybe this can be added?
(2020-08-13, 13:43)Lasse Deleuran Wrote: [ -> ]It does indeed. So the issue is that the search does not consider keywords. Maybe this can be added?
The search can consider keywords but only searches the filename and description by default. You have to select the search header option on the search page to have it consider the keywords lines.
(2020-08-13, 14:08)Orion Pobursky Wrote: [ -> ]The search can consider keywords but only searches the filename and description by default. You have to select the search header option on the search page to have it consider the keywords lines.
While I was looking into changing the default, I found that there was a minor error in the menu bar search box (pointing to the wrong script). This has been fixed and the default changed to header search.
