2020-08-10, 18:00
this release contains just one bug fix regarding the shortcut assignment.
I am currently developing a new offline web application (LDPartMaker / LDPE 2.0).
You'll find a screenshot from the early development version attached to this post.
Changelog:
(1 bug fix)
With this release the following critical issue isfixed:
System Requirements:
Minimum System Requirements:
Changelog:
(1 bug fix)
- Some keyboard keys can't be properly assigned as a shortcut for the 3D editor view (e.g. the 'R' key).
- Download the zip-Archive
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
