Part 4210 (ex-4208) says it needs teeth. It also needs the holes through the drum spindle.
If anyone has the real part handy:
- How many teeth should it have? I think 40, but it's hard to tell from photos alone. (The similar part 2585 has 32.)
- What's the diameter and position of the hole? (In 2585 it's 6 LDU diameter and centered 5.5 from the inner flange.)
(2020-07-29, 16:31)N. W. Perry Wrote: [ -> ]Part 4210 (ex-4208) says it needs teeth. It also needs the holes through the drum spindle.
I've attached the LDD mesh for the part, if that helps.
(2020-07-30, 6:56)Alex Taylor Wrote: [ -> ]I've attached the LDD mesh for the part, if that helps.
Seems to be accurate. I counted 44, both on the real thing and the ldd mesh.
(2020-07-30, 7:12)Magnus Forsberg Wrote: [ -> ]Seems to be accurate. I counted 44, both on the real thing and the ldd mesh.
Thanks, that'll be helpful.
Hmm…44 teeth doesn't adapt quite as neatly to 16/48-prims as 40 would; it means subparting the flange into only 4 slices instead of 8. Is it better to go for the correct number of teeth, or streamline the geometry a bit with greater use of subparts?
For comparison, here's what I came up with for a 40-tooth version (pinhole not finished yet):
attachment=5565]
attachment=5564]
I think I would make a 1/4 subfile with 11 teeth, or maybe better, a 1/8 with 5,5 teeth.
Attach the inner side to a 4-4ndis around the shaft, and hide the outside under the smaller cone.
btw.
dont use the stud3 primitive like that. I know it was used like that in the old file, but must be corrected now.
(2020-07-30, 15:27)Magnus Forsberg Wrote: [ -> ]I think I would make a 1/4 subfile with 11 teeth, or maybe better, a 1/8 with 5,5 teeth.
I'll do the 1/8th then, since it solves both problems (accurate number of teeth, and greater use of subfiles).
Quote:Attach the inner side to a 4-4ndis around the shaft, and hide the outside under the smaller cone.
So the ndis on the inside replaces the disc that's there now? And the cone just the way I have it now, hiding the outside of the subpart?
(By the way, my current version is based on 2585.dat as far as how the prims overlap the teeth subfile. But I can see how the ndisc is an improvement.)
OK, I'll replace it. What should it be, a cylc?
And for the pinhole, I'm thinking a cyl, a cone and a cylj (subfiled of course)?
(2020-07-30, 17:35)N. W. Perry Wrote: [ -> ]And the cone just the way I have it now, hiding the outside of the subpart?
No, I would hide it under the smaller cone prim. The bigger cone is better included in the 1/8 subfile.
(2020-07-31, 6:54)Magnus Forsberg Wrote: [ -> ]No, I would hide it under the smaller cone prim. The bigger cone is better included in the 1/8 subfile.
OK. What's the advantage that way? My thinking was to hide the overlap between the primitives and the uneven number of teeth (to avoid gaps).
(2020-07-31, 16:12)N. W. Perry Wrote: [ -> ]OK. What's the advantage that way? My thinking was to hide the overlap between the primitives and the uneven number of teeth (to avoid gaps).
I'm thinking the teeth are part of the sloping cone, so the bigger cone has to also be adapted to the 44 teeth. And the edge line.
If you allow the bigger cone to switch from 16 to 48 is wouldn't fit the 44 teeth.
(2020-07-31, 16:48)Magnus Forsberg Wrote: [ -> ]I'm thinking the teeth are part of the sloping cone, so the bigger cone has to also be adapted to the 44 teeth. And the edge line.
I think I get it. So the larger cone, instead of a primitive, should be directly modeled, along with the 44 teeth, to match a 48-sided inside edge and ring…and the transition between those and the smaller 16-sided cone and rings in the main part gets hidden behind them?
attachment=5576]
Something like this.... But with 5,5 teeth of course.
Keep the green cone. Make an adapter surface (light blue), and a 44-sided cone (light pink and yellow)
(Here I inlined 48-sided primitives, but you need to make it "44-sided", matching the 5,5 teeth.)
Make a 1/8 subfile that will attach to the pink 4-4ndis and three vertices in the green cone.
(2020-07-31, 21:12)Magnus Forsberg Wrote: [ -> ]Something like this.... But with 5,5 teeth of course.
Brilliant, thanks for the guidance. I was just getting started with the cone as the adapter surface instead of the disc, but I see this way will probably look cleaner.
I'll use PrimGen2 to get the vertices for my 44-sided serrated polygon. :-)
A completed draft:
attachment=5577]
attachment=5578]
I'm not thrilled with how the pinhole blends with the shaft (or doesn't blend) when prim sub is on. I could minimize gaps by using more and skinnier cyl segments, I suppose.
Also, this part would benefit from a cylj2_3x4, if it existed (I had to manually invert cylj3x4).
(2020-08-01, 7:08)N. W. Perry Wrote: [ -> ]A completed draft
Excellent!
The only thing I don't like is the long centre cylinder, and the short one inside the hole, being divided, into the subfiles.
Don't split things going across a main axis.
1 16 19 0 0 0 -38 0 6 0 0 0 0 6 4-4cyli.dat
1 16 -23.5 2.857 0 2.5 0 0 0 -5.714 0 0 0 2.5 4-4cyli.dat
(2020-08-01, 13:46)Magnus Forsberg Wrote: [ -> ]Excellent!
Great! I've moved those cyls, and the pinhole subfiles, up into the main file.
Glad to try my hand at a part with some actual geometry. :-)
Just one vote away (in the
s01 subfile) from moving to the admin review stage.
Thanks to all for your reviews and feedback!
