2020-07-23, 0:37
I only use LDraw to build official models, not MOCs. But although I don't need to create instructions, I like the build process in my model to match the official ones as closely as possible. (That's for the same reason I like the model itself to closely match the real model; it's all just part of the fun.)
Back in my Bricksmith days, I often used rotation steps to match the view in the official instructions, but I'd never experimented with buffer exchange. Since LDCad supports both, I decided to add them to my latest model and see how it affects the workflow. Here are some of my observations—and please regard them as just that: some ideas or suggestions perhaps, but no criticism intended. :-)
ROTSTEP
LDCad's implementation is a lot more intuitive than Bricksmith's. It's easy to set up the rotation you want—I don't get too precise, so I just use relative steps, but I could always match the instruction views exactly with absolute steps. (Haven't figured out a need for additive steps yet.)
There are a few drawbacks:
Traditionally this is used to put parts in a temporary position for a step or two, but I used it almost entirely for another reason. Recent official instructions tend to include large sub-builds within the main step sequence, so you need the model to "disappear" for a while until you finish the sub-build, then "re-appear" so you can insert it.
Buffer exchange works very well for this. To make the model disappear, just RETRIEVE any unused buffer (I use buffer Z). You don't have to store an empty state ahead of time, though it might be a good idea if you plan to open the model in other programs.
I did all 249 steps of the model this way, and used up every last buffer from A to Z with none to spare, before realizing that you actually can have 26 simultaneous buffers! So you can just use buffer A over and over again, only advancing to the next letter if you need overlapping buffers. (For example, if a buffer occurs in a subfile, I start with buffer S and count from there, leaving A-B-C etc. for the main file.) I ended up with a maximum of 3 buffers active at any one time, to accommodate nested sub-builds in the instructions.
Like ROTSTEP, there are several drawbacks (none of which are really news):
I can't think of just a single solution to provide the functionality of buffer exchange while solving this fundamental problem, but in another thread I did propose a pair of new metas, HIDEALL and FLOAT, that taken together I believe would. (HIDEALL would be used to clear the view up to that point, then reveal it again later with an END command, or UNHIDE ALL; FLOAT has been discussed extensively and would be used to provide temporary position and other information without having to duplicate type 1 lines.) Also, as mentioned above, being able to use REMOVE GROUP might be handy in some situations.
I think my verdict is, while ROTSTEP and BUFEXCHG do work well for my purposes, given the inherent drawbacks along with the added steps to my workflow I don't think I'll be fully adopting them just yet. But I did learn some things, so I thought it would be worth sharing!
ROTSTEP
- ROTSTEP necessitates using trackball camera control, which I really still can't get used to.
- With relative steps, it depends on what the default view is. For perspective views, the default can be either left-sided or right-sided. It could be handy if LDCad allowed setting a default view per file, and maybe also allow fine-tuning the rotation for default views.
- Because step commands go at the end of each step, if the final step in your model is a ROTSTEP then it adds an extra (empty) step to the model. This is only a problem for those of us who like things all nice and orderly. ;-)
- Buffer exchange is an either/or operation. When you retrieve a stored view, you lose whatever work you've just done; you can't, for example, add a stored view to your current one. MLCad's REMOVE GROUP meta is said to allow more flexibility in certain cases, but LDCad doesn't support it at the moment.
- If an assembly appears unrotated throughout a subfile, but rotated in the main model, you have to add a step to the end of the subfile to show the rotated assembly. Again, this is only a problem if your OCD kicks in, which for me is usually. :-)
- As with all BUFEXCHG applications, it's necessary to re-insert everything you've added between STORE and RETRIEVE. In my case this means creating a subfile for each standalone section in the main step sequence, together with the individual instances of all those parts in the steps themselves.
