2020-07-18, 7:39
2020-07-18, 8:02
"LDraw Specification" at https://www.ldraw.org/library/tracker/ref/ points to "Documentation" Either Specification or Documentation should be renamed.
https://www.ldraw.org/library/tracker/ref/reviewinfo/ should be integrated into the stub at https://www.ldraw.org/library/tracker/ref/reviewfaq/ (and the page should be sanded).
2020-07-20, 14:00
(2020-07-18, 8:02)Willy Tschager Wrote: [ -> ]"LDraw Specification" at https://www.ldraw.org/library/tracker/ref/ points to "Documentation" Either Specification or Documentation should be renamed.
As you may have noticed, the PT Reference section is now removed and all its content moved to the newly renamed "Documentation" menu.
2020-07-20, 14:02
(2020-07-18, 7:39)Philippe Hurbain Wrote: [ -> ]"General Part Numbering", end of "Unknown Part Numbers": soley -> solely
This is fixed
2020-07-20, 16:14
(2020-07-20, 14:00)Orion Pobursky Wrote: [ -> ]As you may have noticed, the PT Reference section is now removed and all its content moved to the newly renamed "Documentation" menu.
Excellent! Thx
2020-07-20, 16:34
https://www.ldraw.org/ptfaq.html needs sanding.
* "Parts Tracker FAQ" should be removed as it is already in the title.
* All the -CS, -CS & SB, -FWC 2002-4-5 should be deleted.
* "Eventually, it will also be the place to request certain parts be made for LDraw." never happened a link to the forum should be made
* "Available folders are:" Texture is missing and make sure this is ironed out: https://forums.ldraw.org/thread-24107.html
* "Never replace a part that's not your own part (unless you've got permission from the author)!" is no longer true. We have special polices in place: https://www.ldraw.org/library/tracker/ref/policy/
* "How do I post a review?" should point to https://www.ldraw.org/reviewfaq.html or be integrated
* "When will the parts be released?" A "few months" to "a couple of years" would be a fairer answer
* Care about branding is up to you
2020-07-20, 16:43
(2020-07-20, 16:34)Willy Tschager Wrote: [ -> ]https://www.ldraw.org/ptfaq.html needs sanding.
I just copy and pasted what was there. I'll be polishing it over the next week or so.
