2020-06-01, 8:46
Hey,
this release took a little bit longer than expected, but it includes now 6 bug fixes. And three minor usability enhancements.
Some of the issues were indirectly reported by Gerald and Willy. They provided their log files and I was able to spot some critical entries.
Thank you both!
Changelog:
(3 new features and 6 bug fixes)
System Requirements:
Minimum System Requirements:
Thank you both!
Changelog:
- ...use a button to re-open the 3D view (if no view is shown)
- ...see a warning if you try to configure a shortcut key which can't be assigned.
- ...start the program with a broken config file (it's not a bug, it's a feature...).
- The program could break if a subfile refered to a non-existent or read-protected nested subfile in very rare cases.
- There was a critical selection problem which occured if you have tried to select a single quad, but you deactivated the selection of quads before (selection filter).
- It was problematic if the program could not read from the official and unoffical LDraw library folder.
- It was impossible to save a file if its directory does not exist anymore.
- There was a breaking bug which could deactivate the duplication check on a single file (did not affect other files).
- Pressing the ESC key reset the (scale) snapping to an unexpected 2.00 value.
- Download the zip-Archive
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
