Full Version: 0.8.50 Beta Released (bugfix / usability)
Hey,
this release took a little bit longer than expected, but it includes now 6 bug fixes. And three minor usability enhancements.
Some of the issues were indirectly reported by Gerald and Willy. They provided their log files and I was able to spot some critical entries.
Thank you both!
[Image: imgDuke2.png]
Changelog:
(3 new features and 6 bug fixes)
  • ...use a button to re-open the 3D view (if no view is shown)
  • ...see a warning if you try to configure a shortcut key which can't be assigned.
  • ...start the program with a broken config file (it's not a bug, it's a feature...).
  1. The program could break if a subfile refered to a non-existent or read-protected nested subfile in very rare cases.
  2. There was a critical selection problem which occured if you have tried to select a single quad, but you deactivated the selection of quads before (selection filter).
  3. It was problematic if the program could not read from the official and unoffical LDraw library folder.
  4. It was impossible to save a file if its directory does not exist anymore.
  5. There was a breaking bug which could deactivate the duplication check on a single file (did not affect other files).
  6. Pressing the ESC key reset the (scale) snapping to an unexpected 2.00 value.
  1. Download the zip-Archive
  3. On windows, double-click "run.bat" to start LDPE.
  4. On linux/mac, you have to excecute the shell script "run.sh" to start LDPE.
Please note that this software is in the beta stage. Although, this version was tested, there are already known issues  for this release. There is a potential risk of data loss.
  2. On linux/mac, you have to excecute the shell script "update.sh".
System Requirements:
Minimum System Requirements:
  • 64-bit Java Runtime Environment (JRE) 1.8
  • Operating System (64-bit): Windows [7 or newer], Linux [e.g. Ubuntu Linux >=14.4], Mac OS X [>=10.6]
  • RAM: 4GB
  • Video-Memory: 1 GB
  • Free Disk Space: 100 MB
Recommended Requirements:
  • Operating System (64bit): Windows 7,8,10, Linux [e.g. Ubuntu Linux >=14.4], Mac OS X [>=10.6]
  • OpenGL 3.3 compatible Graphics Card
  • RAM: >4 GB
  • Video-Memory: >1 GB
  • Free Disk Space: 512 MB
  • For a faster start, LDPartEditor and the LDraw™ library should be installed on an SSD.
java -d64 version
I don't know how, but I've already got 0.8.50 for some reason!
I will, however, download this version and use it instead. Smile
(2020-06-01, 8:46)Nils Schmidt Wrote: [ -> ]
Thanks Nils,
which one is the one I reported? Just curious.
Quote:
  1. Pressing the ESC key reset the (scale) snapping to an unexpected 2.00 value.
Thanks for fixing this one!
...And any update on this?  Big Grin  https://forums.ldraw.org/thread-23708-po...l#pid34270
(2020-06-02, 9:07)Philippe Hurbain Wrote: [ -> ]...And any update on this?  Big Grin  https://forums.ldraw.org/thread-23708-po...l#pid34270 (a post about keyboard shortcut customizations which are not saved)
Hm... you should retry it Wink Maybe you willl see a warning. I implemented a feature especially for this purpose:
In the changelog I Wrote:...see a warning if you try to configure a shortcut key which can't be assigned.
(2020-06-02, 15:00)Nils Schmidt Wrote: [ -> ]Hm... you should retry it Wink Maybe you will see a warning. I implemented a feature especially for this purpose:
No it doesn't work - but in a very subtle way.
In my current configuration (coming from the older 0.49 version) I had R as shortcut for Rotation (working) AND manipulator reset (not working "of course").
Now I edit keyboard shortcuts to set '<' for rotation and Z for manipulator reset. Both work. (and I can close LDPE, shortcuts properly saved). But since after years of usage I got used to R shortcut for rotation, I change back < to R for rotation, and leave Z assigned to manipulator reset.  This works till I close LDPE... but when I restart it, R is automagically assigned back to reset manipulator (but remains also assigned to rotation, so reset manipulator is no longer accessible)
(2020-06-02, 15:50)Philippe Hurbain Wrote: [ -> ]No it doesn't work - but in a very subtle way.
Thanks Philo! I was able to reproduce the problem from your description and created an issue (#753). I will just correct it with the next release.
(2020-06-01, 17:17)Willy Tschager Wrote: [ -> ]Thanks Nils,
 I found indications of the first three cases in your logfile. They can probably cause the problems which you have observed.
It is very hard to reproduce the four issues you have reported via mail.
This includes (for documentation, maybe I will solve this in the near future):
  • An entry under "Last opened files" is not opened inside of the text editor, even when "Sync. 3D Editor Tabs with Text Editor Tabs" is active.
  • "Cut" or "Delete" does not work in the text editor sometimes, you have to save the file to continue.
  • "Sync. 3D Editor Tabs with Text Editor Tabs" does not sync the tabs sometimes.
  • An Edger2 run somehow "locks" the unmatched edges inside of the text editor. They can't be cut or deleted until you save the file to continue.
I set SPACE as alternative middle mouse button in 0.49. Now this behaves really strange  - actually not usable while the middle mouse button suddenly works. Anyway I will switch back to 0.49. When I press the SPACE bar now it first rotates my part upside down. If I release and press again to somehow get to the view I want all gets suddenly zoomed in and also distorted.
Edit: All the above is true only for the Linux version.
[attachment=5331]
(2020-06-02, 20:02)Willy Tschager Wrote: [ -> ]I set SPACE as alternative middle mouse button in 0.49. Now this behaves really strange  - actually not usable while the middle mouse button suddenly works. Anyway I will switch back to 0.49. When I press the SPACE bar now it first rotates my part upside down. If I release and press again to somehow get to the view I want all gets suddenly zoomed in and also distorted.
Looks like your Linux system has issues with OpenGL 3.3 in the video driver. This is unfortunately normal for e.g. older Intel CPUs with build in graphic chips.
Try to deactivate it via unchecking "Tools..." -> "Use OpenGL 3.3" and then restart LDPE.
I spent some time to investigate on how to improve the compatibility check for this feature, but I have still no practical solution.
And it probably needs a better name. It is too technical. Even for a experienced LDraw user.
I have an issue that was also present in my previous version (also 0.8.50); I don't know if it's related to anything I've reported previously. When expanding the text editor into view, some buttons are missing until I mouse over them. I'll let the image speak for itself (click to view animated GIF):
[attachment=5334]
This issue persists when using OpenGL 3.3 as well.
(2020-06-03, 18:02)Nils Schmidt Wrote: [ -> ]Looks like your Linux system has issues with OpenGL 3.3 in the video driver. This is unfortunately normal for e.g. older Intel CPUs with build in graphic chips.
It didn't solve my problem. I always used OpenGL2.0 also in the past. Funny thing is when I activate 3.3 the header still says OpenGL 2.0. The only difference is the tick in the options.
"sometimes", rotation of an element result in excessive number of digits. When you try to apply rounding tool to that result, nothing happen.
Example of such line:
1 16 .00000000000000000000000000000212293491784143431108835 70.000000000000000000000000000001 -10.000000000000000000000000000032 -3.0614674589207171555441788133124 0 7.3910362600902944708123019945409 7.3910362600902944708123019945409 0 3.0614674589207171555441788133124 0 16 0 1-8edge.dat
Basically, this was obtained by rotating with a 22.5° angle step the following line after setting manipulator to primitive.
1 16 0 70 -10 0 0 -8 -8 0 0 0 16 0 1-8edge.dat
...but I said "sometimes" because when I try this again it does work (the rotated line has a normal number of digits and rounds properly...
1 16 -.00000000000000000000000000001 69.999999999999999999999999999996 -10 -3.0614674589207171555441788133124 0 7.391036260090294470812301994541 7.391036260090294470812301994541 0 3.0614674589207171555441788133124 0 16 0 1-8edge.dat
Edit: Problem is more subtle than it seemed at first: after the editions I made to document the bug here, I was able to round the first line properly Sad
