(2020-06-01, 7:15)Thom Kok Wrote: [ -> ]Is http://www.ldraw.org/library/updates/complete.zip a zip with all the correct part names? I am new to this forum and would like to avoid an error like this in the future. Or is there a better way to look up all the correct part names for each part?
That zip has the official library of parts, which will have the correct authoritative LDraw names. To look up both official and unofficial (not yet released) parts, use the
Parts Tracker. Some unofficial parts may still be in the process of having their names decided, but searching this forum will usually uncover that conversation if it's taking place.
Other sites like Rebrickable and Bricklink have their own naming systems, so you'd have to refer to those sites (and their associated forums) to confirm their correct part names.
In the AIOI you'll find the visual catalogue of all official parts.
They changed the url of LDraw to the right name and location, but the part name on rebrickable is still the same. I think this topic is done, but still weird rebrickable did not change the part name to the LDraw name. I thought they wanted to keep the same names as LDraw.
(2020-07-14, 17:51)Thom Kok Wrote: [ -> ] I thought they wanted to keep the same names as LDraw.
No. Rebrickable names usually parallel ours but for patterns, all bets are off. If you notice is discrepancy, submit a change request to have the LDraw number correctly listed since this is the basis for PBG export and LDraw file import.
