I used "SoildWorks" to make the part, save it as "STL", and then use "slt2dat.exe"Switching to various styles, and then using" PartDesigner "to open, but I encountered 2 problems:
1. After opening, the part defaults to down instead of up;
2. Strange lines appear;
[img]
https://mini-p.oss-cn-shanghai.aliyuncs....281%29.jpg[/img]
Please post your .dat file.
(2020-05-20, 4:12)ragnarok Wrote: [ -> ]1. After opening, the part defaults to down instead of up;
This could be because -y is up in LDraw's coordinate system.
As suggested by Owen, it's because of y axis orientation in Ldraw system. You can compensate for that either by modeling upside down, or by using a 180° rotation matrix in stl2dat (-m 0 0 0 1 0 0 0 -1 0 0 0 -1)
Quote:2. Strange lines appear;
This comes from a slightly buggy edge lines / conditonal lines generator of stl2dat. To avoid this, I use the raw mode of stl2dat (-raw) then I generate condlines/edgelins with Edger2 (
https://www.philohome.com/isecalc/edger2.htm)
(2020-05-20, 7:55)Philippe Hurbain Wrote: [ -> ]As suggested by Owen, it's because of y axis orientation in Ldraw system. You can compensate for that either by modeling upside down, or by using a 180° rotation matrix in stl2dat (-m 0 0 0 1 0 0 0 -1 0 0 0 -1)
This comes from a slightly buggy edge lines / conditonal lines generator of stl2dat. To avoid this, I use the raw mode of stl2dat (-raw) then I generate condlines/edgelins with Edger2 (https://www.philohome.com/isecalc/edger2.htm)
Thank you very much. I'll try. As expected, there are many things to learn^^
(2020-05-20, 8:25)ragnarok Wrote: [ -> ]Thank you very much. I'll try. As expected, there are many things to learn^^
You're gonna submit the part also to the parts tracker, correct?
It probably doesn't matter here, since the part appears symmetric, but won't a 180 degree rotation result in a mirrored part? Isn't the correct matrix one that multiplies Y by -1? Am I missing something?
(2020-05-21, 4:23)Travis Cobbs Wrote: [ -> ]It probably doesn't matter here, since the part appears symmetric, but won't a 180 degree rotation result in a mirrored part? Isn't the correct matrix one that multiplies Y by -1? Am I missing something?
I don't think so, LDraw axis system is right handed, as I think most axis systems in 3d packages. So a rotation is the right thing to do...
Excuse me, how to make “stl2dat.exe” The "- m" command in rotates 180 degrees around the x-axis and 30 degrees around the y-axis
(2020-06-03, 15:18)ragnarok Wrote: [ -> ]Excuse me, how to make “stl2dat.exe” The "- m" command in rotates 180 degrees around the x-axis and 30 degrees around the y-axis
I think you should learn to use LDPartEditor... I generally make a very raw conversion, then massage it with LDPE!
