2020-05-10, 19:34
2020-05-10, 19:53
(2020-05-10, 19:34)Franklin W. Cain Wrote: [ -> ]A prototype starship, using the Alcubierre-White Warp Drive Proposal. ;-)
Franklin
I saw this on FB. Totally cool.
2020-05-10, 21:05
Your spaceship looks very nice, I like the front "shield" protecting the central parts!
2020-05-12, 1:56
Version 2 -- Improved (beefed up) the Ring Drives.
Franklin
Franklin
2020-05-12, 8:35
(2020-05-12, 1:56)Franklin W. Cain Wrote: [ -> ]Version 2 -- Improved (beefed up) the Ring Drives.Great too! But I somhow miss the detail I preferred on the first version, the ingots used to texture the smaller rings
Franklin
2020-05-13, 2:37
(2020-05-12, 8:35)Philippe Hurbain Wrote: [ -> ]Great too! But I somhow miss the detail I preferred on the first version, the ingots used to texture the smaller rings
Thank you, but the first version used a non-existent part that can not be "crafted" (i.e. modded) from other, existing parts -- it uses a 1x2 plate with click-hinges at both ends.
Both versions also need a 4-L Technic beam, but the two needed can be modded from surplus beams.
Both versions also need a 40-L Technic axle, but this can be creatively replaced by two other axles of great length, carefully arranged to meet inside the octagonal "sphere" (the Engineering module).
Thank you for the feedback. ;-) Franklin
2020-05-13, 18:04
(2020-05-13, 2:37)Franklin W. Cain Wrote: [ -> ]Thank you, but the first version used a non-existent part that can not be "crafted" (i.e. modded) from other, existing parts -- it uses a 1x2 plate with click-hinges at both ends.
Same as Philippe, I prefer the first version with "thin" circles.
You can use 14419 or a combination of 18649/ 61252 (X2). Probably other solutions exist, ask to HAL.
[attachment=5211]
2022-10-09, 14:56
Version 2.a ;-)
Found a way (that I liked) to restore the greeblization of the rings.
Also added a "cage" of (transparent) Technic pieces, to aid in keeping the physical model stable, if I ever try to build this thing in Real Life.
Franklin
Franklin
